Was thinking of a high top with an extending bed before we switched to the pop top route. Our plan was to use interlocking pieces of wood to act as a slide. This being the motivation: https://gnomadhome.com/diy-van-build-pullout-bed-frame/
Are you planning on having any rear drawers or putting the mtbs on a slide?
Yes the mtb slide is done. I'll be taking out the seatpost/saddles so that I get a few more inches of headroom. I've also put up new wall paneling over the exiting utility ply. The bed build is delayed until I'm back from EAA Oshkosh in a couple weeks.
The silicone between my 3 month old fiberine top and windshield is peeling already. Should i just trim it? there's another 4" of silicone under the flange.
I used a polyurethane caulking/adhesive by “Sikaflex” - on my high top and it bonds well to the paint if it is sanded first and cleaned off before applying the caulking. It comes in basic colors like white, grey, black, tan, etc...
I self installed my 30" camper top. At the recommendation of Fiberine, I used silicone between the flange and the roof, and (my own decision) used loctite pl marine polyurethane sealant around the edge.
After 20k miles of rather abusive travel around South America, the top remains well sealed.
Starting to get some more projects done. I did the grab handle install that Hammerhome wrote up. I figured out how to use albums here but the rotation is meesed up now http://www.sportsmobileforum.com/for...-up-12665.html
