Originally Posted by Cyrull
Very Nice! Is the vent at the bottom of the sink where your furnace is installed?
It is! I installed a new Espar S2 which has the automatic altitude adjustment and is apparently quieter than previous models. There's a Canadian seller on eBay that has been selling them with EasyStart Pro controllers for $800usd. I bought this mount (
https://www.ebay.com/itm/STAINLESS-D...72.m2749.l2649) to make sealing the hole in floor from the outside easier.
Routing the outlet ducting the way I did might not be the best but it works fine. I had trouble routing the fuel supply and exhaust lines the other way. With the heater reversed the supply line and exhaust had to cross over which was difficult with where I mounted the fuel pump.
