Can you post a few close-ups of your upholstery? What covering material are you using for the cushions? How is your foam stiffness for sitting and sleeping?
Also what are you using to penetrate the roof for the solar panel wire?
The upholstery material I believe is called Nuance. It was one of the softer feeling vinyl's of the ones that we were looking at. Real leather was going to be too spendy and not nearly as durable.
I had the upholsterer put in some decorative stitch lines to break up the single color. I was going to have him cut and stitch two pieces together as that would have been a bit more durable, but it would have made for a crease to collect crumbs/dirt/etc.
I'll try to add a picture of my solar wire penetration. It is just a wire restraint piece from a big box store that I installed upside down and filled the hole with sealant once installed.
We put the awning and screen room to work this weekend. We ended up having a major rainstorm roll through and it was great having the extra dry space. I do get a little water that comes in between the awning and van gutter that may need addressing, but this rain was unlike anything we normally see.
I got the water system roughed in prior to the trip. We will mostly be using this for doing dishes and quick rinses for dirty kids and adults.
It is still a pretty rustic install, but proves its functionality. I still need to build a door panel that incorporates some storage for the wash hose and scrubbers, soap, etc. The shower head that comes with the water heater isn't the most ideal for dishes either. I think I will switch over to a sink sprayer type nozzle that has an on/off valve built in and reduces the flow a little.
