The BF Goodrich All-Terrain T/A KO2 is an aggressive tire made with a superior sidewall design and optimal tread capability to ensure long wear in tough environments. They provide excellent traction in extreme weather conditions and exceed RMA Severe Snow Traction performance requirements allowing the driver to travel with confidence. BF Goodrich considers the All-Terrain T/A K02 its toughest all-terrain tire ever.
The 265/75R16 BFGoodrich All-Terrain T/A KO2 has a diameter of 31.6", a width of 10.5", mounts on a 16" rim and has 657 revolutions per mile. It weighs 53.6 lbs, has a max load of 3415/3085 lbs, a maximum air pressure of 80 psi, a tread depth of 15/32" and should be used on a rim width of 7-8".
