Old 01-14-2020, 11:36 AM   #1
OEM Seat Bracket Orientation
Can someone tell me if the orientation in this photo is correct. I'm mainly concerned with the rear brackets. These are for a Ford OEM three passenger seat. Does the one with the asymmetrical slot go on the driver's side as in the photo or the passenger's side?
Bob
2002 Itasca 35U Motorhome
BCam is offline   Reply With Quote
Old 01-14-2020, 11:58 AM   #2
The ones for the right side will have a "R" stamped into the top somewhere. It may be faint and filled in with paint. I think you are correct however. But your top left bracket might be backwards. I think the "hook" is towards the driver side wall on both legs, to allow you to reach the handle from the isle.
Old 01-14-2020, 12:02 PM   #3
On my 2002 The two brackets with the round hole go in the front, with the holes towards the front of the van and both holes towards the drivers side.
The rear bracket have the notches in them towards the back of the van with the bigger notch on the passenger side.
Just like you have them, if the front of the van is the top of the pic. Except the upper left bracket needs to be rotated 180.
Hope this helps.
Old 01-14-2020, 03:33 PM   #4
Thanks, I had the front two figured out due to the latch mechanism (the photo is from an eBay ad). It was the back two that I wasn't sure of.
I knew someone here could help me out.
Bob
Rattle-n-hum
dar636
Van22
Van22
