10-22-2018, 06:52 AM
#31
Originally Posted by new2tx
I used a regular paper punch for mine. Holes were just the right size.
Same here..worked fine..I suspect that a leather punch will work too but may take more time.
10-22-2018, 09:06 AM
#32
Looking great!!!
Have you checked fit?? I would consider that before moving too much further just in case there's a little grinding that might need to be done. The vans and the tops all have a sculptural element to them.
Just a thought. But it looks like you are on your way!! Nice.
<br>
10-22-2018, 10:09 AM
#33
Originally Posted by Flux
Looking great!!!
I will check fitment for sure,but need to figure out how to move it up. It is
heavier than expected. This also makes me wonder how much it will change
the center of gravity and how it feels while driving. I thins this entire
complete setup must add another 300lbs on the top.
Does anyone remember the difference in feel or handling before and after
the penthouse install?
2001 E350,Denver fleet 4x4,5.4V8
10-25-2018, 09:30 AM
#34
So,after few estimates for canvas rebuild that were almost $2k,I have decided to make my own. I can rent commercial sewing machine from a gentleman who runs sewing machine repair shop.
Before I get the material and the machine,I will rebuild the lifting mechanism.
I'll be using extruded aluminum profile from free roof rack with a slider.
I managed to straighten the resting rail,but dont like the original design of the sliding part that is damaged anyway.
Hope to post some more details incoming weekend.
10-25-2018, 09:48 AM
#35
Way to not give up! Very excited to see how your canvas turns out and what you come up with for the lift mechanism.
10-25-2018, 10:12 AM
#36
You really did "resurrect" that Top - looks great!
10-25-2018, 02:57 PM
#37
I use waterproof ripstop for mine and Stitch it with a regular home sewing machine also check out my build for some different designs on lifting mechanisms mine goes up with the gas struts super easy super simple there's no weird leverage on any part of it and even if I have a gas strut fail I can still lift it up
10-25-2018, 05:23 PM
#38
I did for sure. But my van was still empty. Mostly it was going around a curve at highway speed with no real grading, just felt like the van was tipping a bit more than I had been used to. Once I built out the van that subsided a bit as all the junk lowered the COG. But still, there are certain roads where there is no grading on turns that make the van feel tipsy. It's just a feeling though.
Good on ya for making your own canvas. I have an industrial sewing machine and it's more about time and effort.
<br>
10-25-2018, 09:13 PM
#39
Good job on the your canvas. I saw your tread earlier and I enjoyed watching your progress on the build.
I am not sure if gas struts would hold the weight of the PH that is much heavier than I expected.
I have come up with this slide mechanism and did some "test run" on one side. Seem to be working ok. Some hardware changes will need to be done. Mainly nylon nut and nylon washer in between the arm and rail.
10-28-2018, 12:58 PM
#40
Just one quick update.
One side of lifting mechanism is finished,now I need to do the same on the other side. I will reuse the top hoops of the original lift bars. I cut them so I can insert them into 1"1/4 square tubes. Square tubing is 11 gauge and round bars slide perfectly in. Also installed new gasket for the lid.
