Old 10-18-2009, 10:04 AM   #1
GreyDawg's Avatar
Plastic or other moisture barrier on steel van floor?
Hi --
Today I am cutting and fitting the unfaced synthetic fiber insulation for the van floor. I have four options:
1) fiber insulation directly on the steel floor
2) fiber insulation on a 0.7mil sheet of plastic (painter's dropcloth!) on the steel floor
3) fiber insulation on a radiant barrier film (foil on one face, kraft paper on the other) -- roll left from a house insulation project
4) fiber insulation directly on the steel floor, and plastic dropcloth between the insulation and the plywood.
The objective is to keep the steel floor from developing rust from condensation.
Thoughts about which solution to pick?
Thanks,
GreyDawg
GreyDawg is offline   Reply With Quote
Old 10-18-2009, 11:11 AM   #2
WVvan's Avatar
Re: Plastic or other moisture barrier on steel van floor?
Don't use fiber insulation on the floor. It's the air in between the fibers that gives it any insulating properties. The puffier the better. If you put it on the floor it will be flattened, ie no air giving insulation. If you are going to use insulation use the rigid kind. The air is trapped inside the foam. It will probably still flatten out some when used on the floor but not near as bad as fiber.
Condensation is caused by moist air which tends to raise. The moisture problems will be on the walls and ceiling. Of course the water could drain off the walls onto the floor but that's a different issue.
Use the fiber on the walls or ceiling where it won't flatten.
Open the pod bay doors Hal.
WWW.WVBIKE.ORG
Old 10-18-2009, 01:57 PM   #3
spurious's Avatar
Check out other cars Mercedes etc. All use a Jute sound deadning material(It is not Fiberglass based, but a wool and cotton blend). The idea is if there is moisture it is able to breath out in time. That is also why you don't want plastic it will not allow it to breath and trap natural moisture between metal and plastic resulting in rust.
Jute also comes in foil backed, and in various weights.
spurious is offline   Reply With Quote
Old 11-03-2009, 03:46 PM   #4
So, what's the solution to a vapor barrier?
Also, is there some kind of insulating subfloor that would works well in this type of van?
zippy is offline   Reply With Quote
Old 01-28-2010, 10:07 PM   #5
12bproper's Avatar
just an idea, install a dehumidifier???
2003 e350 ext. 7.3 psd, keeping it prerunner-added python remote start, buchwackers fenders, pro comp rims 17X9 steel, nitto grapplers AT 34s, camburg suspension 6", deaver rear springs, alluminess nerf, ladder, rear bumper, galley box, spare rack. Working on: arb on board air, rear locker, and 410 gearing.
12bproper is offline   Reply With Quote
Old 01-29-2010, 10:23 AM   #6
scatter's Avatar
I'd check into this outfit. I've been very happy with their products.
www.quietride.com
Very complete kits and fit like a dream.
Scatter
2007 RB50, 6.0
K1WGB
Old 01-29-2010, 06:33 PM   #7
campervanbeethoven's Avatar
I wouldn't put any thing between the steel and your subfloor. use marine grade 3/4 ply for subfloor and then add your insulation on top. I just relied on 1/2 inch capet padding and a nice nylon carpet. works ok, if you want somthing more substantial fir on top of the subfloor (16" centers) and lay blue foam insulation of desired thickness between fir strips. (ie 1" or 2") then add another layer of plywood. This time just use cheap cdx. 5/8" would be plenty. this will produce a well insulated floor with the abillity to breathe. if you go with the sandwich style floor you can use 1/4" marine plywood on the bottom instead of 3/4" and gain a half inch of head room.
campervanbeethoven is offline   Reply With Quote
