Old 09-13-2013, 08:35 PM   #21
Re: Popping my top
HAHAHA, it will fit, we will call it ours!!!!!!!
shadzima is offline   Reply With Quote
Old 09-14-2013, 08:00 PM   #22
Re: Popping my top
A timeshare!
2008 E350 RB passenger advanced 4WD SMB penthouse
2000 KTM 200 EXC
2006 Honda CRF 250X
Old 09-15-2013, 04:07 AM   #23
Re: Popping my top
Budget-wise how much will you be saving going this route BoyWonder?
Old 09-15-2013, 08:11 AM   #24
Re: Popping my top
So far:
Used RB Penthouse-$2K
Headliner material and adhesive-$100
Yakima Tracks-$100
Cro-mo tubing for support mods-$100
LED lights-$100
New rubber trim, stop light and roof tape-$167
Shoulder screws and other stainless fasteners-$50
Butyl sealant tape-$35 (McMaster-Carr)-haven't purchased yet-don't know if it's the right stuff
paint and primer-haven't purchased yet
penthouse bed-still need a "make or buy" decision....
So around $2600 so far plus a day for the extraction and at least another day for installation
So.....the top is completely functional, no bent tubes, upholstery trim and springs chain are all there, fluorescent lights work, canvas is fine, stop light works....all of the above are upgrades...so without upgrades it's $2K for the top and $36 for a roll of butyl sealant.
I'm up at Bass Lake for the weekend; I drove by Sportsmobile Fresno on the way up......may have to stop by there on the way home.....
2000 KTM 200 EXC
2006 Honda CRF 250X
Old 09-20-2013, 08:05 PM   #25
The project continues......
Got some time to fabricate a new headliner for the top.....
1/8" Baltic Birch was used for the new headliner base plywood. Since BB comes in 5'x5' sheets, this allowed elimination of one of the joints in the headliner since I would only need 2 pieces (SMB uses 4' x 8' sheets of plywood requiring 3 pieces). The total length of the headliner is 48+48+21.5=117.5" x 53" wide.
Using the old headliner pieces as a template, holes were drilled in the new ply for the J hooks, padded support thingies, lights, etc. and the end corners were radiused. The new pieces were cut about 1/16" undersized all the way around to allow room for the folded-over padded headliner.
Before gluing on the material, the wood was test-fit to the top to confirm that everything lined up and that I had space for the material wrapped around the edges.
The headliner material was purchased online at http://www.yourautotrim.com. These guys have lots of choices, from regular stuff to ultrasuede, perforated vinyl and even camo headliner material. I bought a headliner sample kit before ordering the material to evaluate the color match with the rest of the PH trim. The color is called PH1769 charcoal and it's a close match to the SMB grey velour fabric. I also bought 3 giant spray cans of DAP weldwood high strength contact adhesive from the same place.
Here are a few action shots:
Laying out the prepped plywood on the back (foam side) of the headliner fabric
Spraying the contact adhesive (also applied contact adhesive to the plywood not shown...)
Carefully "rolling" the plywood on the headliner without making any bubbles.....the only real stressful part of the job.
Using a veneer roller to get the pieces stuck together
Applying a 2" strip of contact adhesive to the perimeter of the wood and folding over the material. Note the mitered corners.
The finished product! (repeat steps above for second piece...)
I still need to poke holes in the fabric at various places and will attempt this with a leather punch.
2000 KTM 200 EXC
2006 Honda CRF 250X
Old 09-21-2013, 04:35 AM   #26
Re: Popping my top
Very very nice job applying the headliner material!
I've seen that done differently but finished results don't always rely upon just one process.
Your PH is coming along nicely----that new van on your horizon yet?
Old 09-21-2013, 07:58 AM   #27
Re: Popping my top
Thanks! What's the other process for making a headliner? Curious....
Still looking for a van......
2000 KTM 200 EXC
2006 Honda CRF 250X
Old 09-21-2013, 02:10 PM   #28
Re: Popping my top
You bought your pop-top before owning a van, please don't tell me you're going to make a headliner before buying a van?
We need to get you a van, and get you one soon. Can we help? What are you looking for?
Old 09-21-2013, 04:02 PM   #29
Van-aholic
.....it's a slippery slope.......
"Hi everyone! My name is boywonder and I have a van problem......"
Headliner is mostly done....anybody know where I can get one of those joiner strips for the headliner that's a little thicker? The padded panels are a tight squeeze on the SMB one.
Just got the cro-mo tubes drilled for the crossbars....
Next up, mount the Yakima tracks and source some cool LEDs for the new headliner.
and (almost forgot) mount the solar panel
No real hurry on the van, I'll find one. I'm combing the countryside rather heavily for a 2WD 2009+ RB van in either red color, dark grey or possibly silver. Preferably a window van, although I'll entertain a cargo van if it has enough windows and power/cruise. I can't do white or black. If I was looking for a white van, I'd have a couple dozen in the driveway by now.
The only thing I can't do without having a van is paint the top.....soon enough.
2000 KTM 200 EXC
2006 Honda CRF 250X
Old 09-29-2013, 02:13 PM   #30
Re: Popping my top
Continuing on.....
The crossbars were reinforced with 4130 cro-mo tubing. I picked up the tubing at my local metal supplier (Industrial Metal Supply (IMS) in Irvine.
The tubing is .750 OD x .065 wall by 54" long DOM (drawn over mandrel...ie seamless) chrome-moly.. 4 pieces with tax was right around $100 or so including cut charges. Full lengths are 20' (I needed 18' total) and are probably slightly cheaper but I paid the cut charges to make them easier to haul. Also, as a side note, mild steel DOM tubing the same size is about $30 for a 20' length.
The yield strengths for mild steel and cro-mo are roughly 40,000 psi and 70,000 psi respectively, so you get almost double the yield strength for 3X the cash.
Two (perhaps) interesting tidbits for this project:
I used a center drill to drill the pilot hole for the end hole, it keeps the bits from wandering in the drill press.
Once the new tubing was inserted in the crossbars I used a shoulder screw in the lower hole to fixture the inner tube to drill the pivot hole. A shoulder screw provides a tighter fit (more accuracy) than a vanilla 1/4-20 screw.
Instead of using a drill press and center drill, the other way would be to slide the new tubes into the crossbars and use the existing holes as your fixture.
Since a few of my existing crossbar holes were rather egged-out, I'm going to use 5/16" shoulder screws for the pivots and the fixed end of the crossbar. I'm also planning on improving the sliding bolt setup where the chain connects and will post pics when I get the new fasteners and spacers.
Center drill
Using a shoulder screw as a fixture to drill the pivot hole
2000 KTM 200 EXC
2006 Honda CRF 250X
Jnlola
jnlola
Le Moose
Stanvan
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
