Old 11-02-2016, 04:42 PM   #1
UpaDowna's Avatar
Propane Heater vent question
Well, with the temps dropping household 6 aka the wife says its time to install a heater. I sourced a nice old Atwood and have it ready for the install but I have a question on the vent. Does anyone know if the vent and be at a 90 degree angle to vent from the van? In other words I am looking to install the furnace body parallel to the wall of the van and then run the vent out through the same wall. Will this work? Is this a horrible idea? Thanks all.
Up a Mountain, Down a Beer
UpaDowna is offline   Reply With Quote
Old 11-02-2016, 05:40 PM   #2
1der's Avatar
Where is your combustible air intake going to be located? That needs to draw from outside.
Old 11-02-2016, 07:00 PM   #3
UpaDowna's Avatar
It is in combination with the exhaust and ideally I want to run it perpendicular to the furnace body so instead of it running straight out the back through the van wall it would be out of the back and then a 90 degree angle then through the van wall. Not sure if it is going to work, although I haven't found any evidence why not, but I suspect the 90 degree turn might be a no no.
It looks like this.
Old 11-02-2016, 08:26 PM   #4
1der's Avatar
See what the install manual says or call Atwood tech. Maybe two 45's can get you what you want.
Be careful on the heated inside air side. That air is really hot, too!
Old 11-02-2016, 08:41 PM   #5
dhally's Avatar
No, check the instructions. The combination intake and exhaust fitting must be attached directly to the furnace. It is somewhat adustablecfor wall thickness though.
That is why some prefer the Propex furnace, which has flex tuning for both intake and exhaust.
2009 E250 RB 5.4L "SilVan"
PolarVan
PolarVan
Jnlola
jnlola
