Originally Posted by tyc221
Can I ask why you recommend the larger one? Dose yours have trouble keeping the van warm? can you give me some insight into how your van is insulated? and do you have a pop top or a fixed top? Any idea what the coldest night you used it was and how warm it kept the van? Thanks for all the info it's hard to decide what heater is going to work best especially when there are so many variables between each users van.
Well it was pretty cold up on Rabbit ears somewhere around -10F(below). Yes I have a hard top and it is insulated along with the walls and floor. The cab area floor still has the factory sound matting but have not insulated it. The heater did a great job for the temp outside but was a bit on the cool side for me and ran non stop. I have a small electric heater we plugged into the generator and that along with the Propex made it comfortable. The other thing that makes it much warmer is hanging a thick comforter from the storage above the cab down behind the front seats to the floor.
If I had it to do over I would install the larger 9000btu, rather have to much heat then not enough.
