Old 06-15-2018, 08:03 AM   #1
jpau00's Avatar
raptor liner cleanup
What would be the suggested solvent to use for cleaning the paint gun?
jpau00 is offline   Reply With Quote
Old 06-15-2018, 08:46 AM   #2
Acetone or reducer. I've just used reducer I had left over from other paint jobs.
Old 06-15-2018, 08:52 AM   #3
I used acetone, based on what U Pol recommends, but I cleaned the gun immediately after each use, running acetone through the pick up tube and through the gun. I then wiped down the gun with an acetone soaked rag to clean up any remaining bedliner.
If you let it dry in the gun, I think you'll be buying a new gun.
Old 06-15-2018, 09:07 AM   #4
Yep ^^. I was assuming you meant when the gun had just been used. Once it's dry, just like auto paint or POR15, it's there for good.
Old 06-15-2018, 11:32 AM   #5
WhitH's Avatar
I concur with Herb and Eric. I used Acetone, and do it right away while the stuff is still wet.
Sold 2005 E350 Chateau
Old 06-16-2018, 12:25 PM   #6
jpau00's Avatar
I had gotten acetone for it. I wasn’t sure if something special was needed instead. Thanks for the feedback.
