Old 03-04-2019, 09:34 AM   #1
Rear AC
I am looking at a few vans for DIY builds. Some of these vans in considering have rear AC. Is the rear AC worth keeping? I live in Orlando, FL and it can get hot here. Any suggestions welcomed.
Brianf7028 is offline   Reply With Quote
Old 03-04-2019, 10:18 AM   #2
Flux's Avatar
Worth keeping. I live in California desert.
<br>
Old 03-04-2019, 10:26 AM   #3
Absolutely worth keeping!
Desert Solitaire
2003 7.3L EB 4x4
Denver Fleet 4x4 conversion
Old 03-04-2019, 10:31 AM   #4
Flux's Avatar
It's pretty easy to enclose the unit and route different vents for it. When I get in my van and it's 100 degrees out I can crank both units. It's hot like that for many months of the year here.
<br>
Old 03-04-2019, 10:53 AM   #5
Im in Orlando also, definately keep it.
Flipperfla is offline   Reply With Quote
Old 03-05-2019, 08:35 AM   #6
IanF's Avatar
I've pondered what to do with the rear A/C in my conversion van. While I agree it would be nice to have, it only works with the engine running. When not in use it takes up interior space.
For a time, I had an idea of fitting a small diesel engine (my van is a diesel) that would turn an automotive R134a compressor and a 250A alternator. I still think it's a workable plan, but not for the limited underside mounting space I have available.
I'll probably remove the rear A/C and replace it with roof A/C and a bank of lithium batteries.
IanF is offline   Reply With Quote
Old 03-06-2019, 08:02 AM   #7
BrianF7028 are you asking about the rear A/C units fed by the front A/C compressor? Those can be problematic for the entire comfort cooling if so. Naturally they're not designed for cooling while parked or camping. I have a few thoughts about those if it would be interesting or helpful.
If you're talking about an RV-type unit I can't add anything to that discussion.
Old 03-06-2019, 08:21 AM   #8
Worth keeping...and as mentioned the vents can be relocated many different places if you are installing a roof...
2000 KTM 200 EXC
Old 03-06-2019, 11:40 AM   #9
Keep it! I ripped mine out and have regretted it ever since.
kccourtney is offline   Reply With Quote
Old 03-06-2019, 12:42 PM   #10
I think a large enough bank of battery's to run an a/c for even a few hours will take more space than you gain removing the AC unit, not to mention the high cost of all the parts.
