Old 03-11-2013, 11:38 AM   #1
Rear ProAir removal
I have a ford van that was equipped with the rear heat and A/C unit, that has since been removed. All that is left are the lines that come down underneath on the driver's side out of the engine bay. They are metal lines and I have them plugged now with a chunk of coolant hose shaped in a "U-turn" to simply allow the lines to push fluid around. However, the coolant hose keeps cracking and creating a leak, does anyone have a permanent way to plug the line that is going to last? I replace this thing about once a month. I have searched for plugs, but can't find anything in the right size. Thanks!
C
c7train is offline   Reply With Quote
Old 03-11-2013, 01:23 PM   #2
AndrewST's Avatar
Re: Rear ProAir removal
You could do a metal u-turn and connect with 2 strait line coolant hose, might crack less.
Old 03-11-2013, 01:59 PM   #3
Use Silicone hose. It can come in any color, but blue is the most common color that is stocked.
Old 03-12-2013, 12:30 PM   #4
dhally's Avatar
We had an auto air conditioning shop remove our rear A/C. They used OEM Ford parts to install under the hood that eliminated the tee's in the coolant lines. Then the coolant lines can be completely removed. The parts were expensive.
2009 E250 RB 5.4L "SilVan"
VanBo
Mike Ponce
Dusty
capnkurt
