i see that wvvan had small sections of the stuff applied. i wonder if that is just as effective and covering everything is overkill?
I used both the expensive and the Lowes version of foil-bubble wrap but I did it for insulation not sound deadening. If you will be camping in cold weather you should cover as many interior metal surfaces as you can. Otherwise you'll get condensation. An inner skin of bubble wrapped stopped all condensation except on the windows.
