Old 02-08-2019, 11:31 AM   #11
Originally Posted by Surfvan View Post
Mothgils- Do you have any plans on this or a specific plan you are going to follow? The video I posted seems like overkill and I like the simplicity of the 80/20 aluminum or Ray's setup (thanks for all the details in your reply Ray) and I'm curious to see what you got cookin up with the L-track.
I don’t have any plans yet. I need to strip out the interior panels to see what I’m working with. I am building a EB into our family camper/adventure rig and would still like to have some of the items removable to haul things if needed. I plan to utilize l-track along the floor and on the walls too.
I was referring to a company called Adventure Wagon. They have a removable bed system called the MOAB that attaches using l-track. They do not have anything for our Ford E vans but the idea could be transferable . I hope to start working on something soon.
80/20 is a good option but unless you find a great deal, it is not cheap.
mothgils is offline   Reply With Quote
Old 02-10-2019, 09:17 AM   #12
Mothgills- this looks pretty cool! Pretty easy install and good storage ideas when not in use. Have you seen this one? Sprinter Van DIY 3 Panel Platform Bed on L Track
Surfvan is offline   Reply With Quote
Old 02-12-2019, 06:52 AM   #13
I haven't seen that build yet, thanks!
I actually was thinking of using those supports. I saw them 2 weeks ago when my wife and I were at IKEA. I stopped and looked at them and said, these might work in the van!
Old 02-12-2019, 08:25 AM   #14
That’s awesome! I ordered 6 of the ikea supports and bought the L-track. I’ll need to find someone to weld those small brackets for me. I’ll keep you posted on how it works out. What part of the country are you in?
Old 02-12-2019, 12:56 PM   #15
I'm in Indiana. If I were farther along in my build, I could make a set and send them your way but I am not sure when I will be diving into it.
Old 02-14-2019, 05:52 PM   #16
ConnieKat's Avatar
Lighter bed
Hi,
I was thrilled to see this post! I need to come up with some way to convert a gaucho type ( side) bed to
one a few inches longer, and a couple wider. I must have memory foam ( bad back), and need to be able to lift up the bed to get to water tank and batteries.
At 68 and female....current set up just doesn’t work for me! I found a 6” deep trifold matress on Amazon
for less than $100 that’s the right siz, but a lighter weight base has defeated me up to this point!
Any ideas, designs, inspirations from anyone and everyone would be greatly appreciated! I have a Chevy 350 EB with a bath that takes up the rear, so it has to be where it currently is....behind driver’s seat.
I don’t need a couch per se, the bed would be much better! I was thinking of the fiberboard with holes as a base for mattress. Any reasons I shouldn’t? The aluminum sounds great to put it on!!!
Thanks everyone,
ConnieKat
ConnieKat is offline   Reply With Quote
Old 05-06-2021, 12:25 AM   #17
Hey, jjuan,
I want to build something similar to what you did with the 80/20...
Do you recall what the series / thickness of the bars you used was?
vwfr34k is offline   Reply With Quote
Old 05-06-2021, 07:05 AM   #18
Did you ever finish your bed? Curious how it turned out.
@1der I like your design. Did you go with marine ply for the frame?
This thread could be really helpful for me.
jamesc is offline   Reply With Quote
Old 05-06-2021, 07:20 AM   #19
1der's Avatar
The best ply to use is the Baltic Birch multi-ply. In this case I used a high quality 3/4" marine multi-ply due to the 48" span over the legs and dowels/holes in the edges where the platform pieces were mating when assembled.
I used 1" x 1" x 1/8" steel angle for the edges. If I were to do it again I would use an Aluminum C Channel.
Old 05-06-2021, 09:23 AM   #20
ConnieKat's Avatar
Do you have a photo of the aluminum “C” channels....and where could I find that? I was thinking of the L channels, but the C would likely hold everything in place a lot better. If you
have pictures, I’d love to see exactly what you have done with the bed?
ConnieKat
