Old 03-16-2015, 02:33 PM   #11
Re: Roof rack solar shower
Originally Posted by 1der
Main issues for me are ability to refill on an extended trip, or in places with no hose, i.e. lake, stream or pump. That is what makes the Solar shower bags more attractive.
.....you forgot....."and lifting the PH roof with 5 gallons of water in the rack".......
I wouldn't try it with a pop top! I thought I might get away with that with a single tube (4" tube) homemade shower on a pop-top. Definitely not for pop tops.
Old 03-16-2015, 03:46 PM   #12
1der's Avatar
Oh, yes, that is also a bit of an issue !
Old 03-17-2015, 12:21 AM   #13
Abitibi's Avatar
That's a great example of how you can always find a little air space in any vehicle that can be used to store something useful. I'm impressed. I'd like to see some more pics of that.
Here y'a go, scroll through p.1
http://expeditionportal.com/forum/showt ... p?t=133049
Cheers
Mr. D
2008 E350 Hambo
2001 E350 AmbuLand (sold)
1970 Econoline popup camper
1965 Econoline Travelwagon
Abitibi is offline   Reply With Quote
Old 03-18-2015, 11:17 PM   #14
REF
REF's Avatar
Send a message via MSN to REF
I'm again looking at the roadshower, they are now made out of aluminum, when I had first seen them a few years ago they were being made from pvc. Local shop carries them, one of the employees said it warms up water pretty nicely.
Old 03-19-2015, 12:48 AM   #15
JackTuppVan's Avatar
Aluminum is an
exceedingly better thermal conductor than PVC .I have seen homemade aluminum solar water heaters constructed from salvaged aluminum drive shafts. simply remove the U-joints and drill and tap the thick end caps paint black and you're good to go.
2007 E250 Super Duty cargo
1988 Toyota Van 4x4 5-spd
Old 03-19-2015, 08:52 AM   #16
Originally Posted by JackTuppVan
Aluminum is an
True, but aluminum and water make nasty white corrosion byproducts over time.........
Old 03-19-2015, 09:18 AM   #17
Maybe of interest:
viewtopic.php?f=16&t=11431
mpfreivald is offline   Reply With Quote
Old 03-20-2015, 09:18 AM   #18
JohnandMandi's Avatar
Nemo Helio Portable Pressure Solar Shower
Placing it on the ladder uses both gravity and the pressure for an acceptable flow, at least to us. Packs down fairly small for storage in the Aluminess box, probably fits in the rear bumper.
-John
2001 7.3 E350 Ujoint 4" w/ SMB Penthouse
johnandmandi.com
JohnandMandi is offline   Reply With Quote
