Old 12-02-2010, 02:18 PM   #1
Rubber Mat Template?
I'm gearing up to start my build and have a quick question.... My '99 E250 has a factory rubber mat the full length of the van. Will I be able to use that as a template for the plywood flooring?
Thanks for your time- Gary
GaryMc is offline   Reply With Quote
Old 12-02-2010, 07:22 PM   #2
Re: Rubber Mat Template?
I don't see why not... just make sure it's not rolled in any corners and actually fits the van floor.
racrx451 is offline   Reply With Quote
Old 12-02-2010, 07:35 PM   #3
I used my as a template, but I did cut about .5-.75" larger than the mat knowing that I would be taking it out again and trimming it a couple times.
One thing that I did do is cut holes in the floor where there are body panel holes in the even I want to run wire or other through the floor.
Rockman is offline   Reply With Quote
Babe
Babe
Bullwinkle
austineats
