Old 05-26-2014, 05:54 PM   #1
Second Row Seat Quick Bolts
Hi all, wondering if anyone knows where to get quick bolts like these one pictured at discountvantruck.com. I need to have them in the next two weeks which rules out discountvantruck.
http://www.discountvantruck.com/rvvanqu ... nnects.htm
Thanks!
Taylor3633 is offline   Reply With Quote
Old 05-26-2014, 06:43 PM   #2
Re: Second Row Seat Quick Bolts
You got that right! Amazon? McMaster Carr?
Currently vanless. Weird.
Old 05-26-2014, 08:05 PM   #3
1der's Avatar
http://www.ragepowersports.com/tie-down ... uick-nuts/
http://www.summitracing.com/parts/rrr-quick-nuts
Could probably get away with a coupling used for joining two galvanized all thread rod.(search all thread coupling) Have a machine shop add threads to the outside 3/4 of the way up so as to leave a hex shoulder. Add fender washer for inside strength. Simpson Strong-Tie plate washer or larger for the bottom, plus lock washer and nut to lock it place. (Lock Tite works well also) all are available in Galvanized but you would probably have to treat the machined threads for rust prevention if that is a concern. Just an idea for stuff readily available off the shelf at Hm-Dpt
Beastie 3: 2002 7.3 EB Cargo: Agile TTB, CCV Mid Top, Custom Walk Through, Lots of stuff added. BlingMyRig.com
Old 05-27-2014, 08:43 AM   #4
Be careful with the Home Depot fasteners. I've broken enough bolts I don't really trust that stuff anymore, aside from the packaged Superstrut hardware in the electrical section.
Reunel rear bumper
Old 05-27-2014, 08:44 AM   #5
Maybe give Van Specialities a call?
Also I know CVCandMore uses those for their conversions. I don't think they normally sell parts retail but you might be able to sweet talk them.
Reunel rear bumper
Old 05-27-2014, 09:14 AM   #6
1der's Avatar
Sorry, I should have clarified re HD of the shelf: I would only use galvanized Simpson Strong Tie components for all of this. It is the stuff that is supposed to hold my house down in an earthquake, hopefully, good enough to hold a seat down in a crash.
Old 05-27-2014, 07:48 PM   #7
Thanks for all of the awesome input guys! Ray, I agree with you about the using Simpson type hold down fasteners; can't be too safe. Then again, I guess a chain is only as strong as it's weakest link...
Old 06-19-2014, 03:32 PM   #8
chaos's Avatar
Thanks!
I just remembered this thread as I wanted to pick some up...
so i just called and they said I would get them in about 3 days.
were they just out of stock?
chaos is offline   Reply With Quote
Old 06-20-2014, 05:00 PM   #9
Thanks!
No, honestly I didn't even call them. Discount Van Truck has a reputation of being very slow.
Old 09-23-2014, 08:14 AM   #10
spurious's Avatar
They are available from your local uhaul. They come with an eyelet bolt, but can be replaced.
This is the product they carry
http://usaprogrip.com/products.php?cat=4
spurious is offline   Reply With Quote
