09-18-2013, 07:05 AM
#101
Re: SOCAL build
Upgraded the core wiring harness last night. I think it weighs 5 pounds, lot of copper in there.
09-18-2013, 07:06 AM
#102
Re: SOCAL build
Originally Posted by Pschitt
Interesting build. Looking forward to see it finished.
Thanks!
09-26-2013, 06:59 AM
#103
Re: SOCAL build
Picked up a rack yesterday, 55"x111". Going to have expanded metal welded to the base with a square cut out for the fan and some angle iron mounted to the front top for my solar panel.
09-26-2013, 07:03 AM
#104
Re: SOCAL build
Going to use ladder racks for mounting the basket. Picked these up really cheap, just needed a little elbow grease.
Also got the VHF antenna mounted.
09-26-2013, 07:07 AM
#105
Re: SOCAL build
Test fitting overhead console, electrical, radios, antennas.
09-26-2013, 07:48 AM
#106
Re: SOCAL build
Just a thought, but you might want to test out those overhead switch lights at night to make sure they're not too bright and/or distracting. I've found a lot of indicator bulbs to be far too bright at night.
Great work though, and I'm very impressed by how quickly you're tackling everything.
09-26-2013, 09:06 AM
#107
Re: SOCAL build
That's where dropping resistors come in handy......
09-26-2013, 09:36 AM
#108
Re: SOCAL build
Good idea, wish that was I reason I tested at night. Only reason I did was to see everything lit up.
Only thing I don't like is the CB is not bright enough to see the channels so I need to angle it.
09-26-2013, 09:40 AM
#109
Re: SOCAL build
Where did the rack come from? Those dimensions would work well for me.
09-26-2013, 09:54 AM
#110
Re: SOCAL build
I will PM you.
