Old 07-12-2013, 11:42 PM   #1
SOCAL build
After about a year of looking and talking to a few knowledgeable folks on here or recommended from here I finally decided to buy a 4x4 van as opposed to having one converted.
I bought a 2000 Ford F350 EB V10 with a Salem Kroger 4x4 6" leaf spring lift with 100k on it. I did spend a lot of time looking, I search about every site you can think of daily. In the end I had to fly 2 hours and drive 8 hours home to get what I wanted.
It is a beast, I have never been almost eye level with 18 wheelers before. It is also a bit skethy to drive, it wobbles but this will be fixed. It was also a work van so the interior needs work. Here are my plans as of today:
Here are a few before I bought:
shadzima is offline   Reply With Quote
Old 07-12-2013, 11:52 PM   #2
Re: SOCAL build
What I sold to buy "The Van". Big difference!
Old 07-13-2013, 08:12 AM   #3
Re: SOCAL build
Welcome to the gang! Good looking van. Your list will get a lot longer unfortunately, but it's a labor of love. Keep us posted as you can, and don't hesitate to ask questions. Lots of good info here.
Currently vanless. Weird.
Old 07-13-2013, 10:33 AM   #4
Re: SOCAL build
Interior cleaned out, now just need to find someone to weld the bolt holes closed that where drilled for the utility shelves in the floor.
Old 07-13-2013, 01:00 PM   #5
Re: SOCAL build
With your interior stripped out and sanded ... now is the time for sprayed in bedliner if you are going that route.
taylorvon is offline   Reply With Quote
Old 07-14-2013, 08:45 AM   #6
Re: SOCAL build
Thanks 86scotty
Taylorvon, I was think that but I am leaning more towards the plywood rubber coin matting mod I have seen on here.
Old 07-29-2013, 01:17 PM   #7
Re: SOCAL build
I was on vacation for a week and while I was gone my brother-in-law completed the following:
Oil\Filter
Fuel Filter
Transmission fluid
Air filter
Spark plugs
Rear Breaks\Rotors and calipers
He still has to install the Pro Comp dual steering wheel stabilizer but needs to weld a mounting bracket.
Also the front rotors need to be machined out to fit. No sure what Salem Kroger does to the front end, best he could figure is a F-350 Super Duty, but some things do not fit right, they need some modification.
He will finish this work up next weekend.
All said and done $1100.00 in parts.
Old 07-29-2013, 01:19 PM   #8
Re: SOCAL build
Went to the body shop this week for a color sand\buff and have the door jams painted. They did a great job. This was a work truck so it needed it.
$650 but worth it.
$20 for the 4x4 stickers
Old 07-29-2013, 01:25 PM   #9
Re: SOCAL build
$1000 in misc parts have been pilling up so time to put them in:
4x4 sticker
Center console for dog house
Driver side interior door panel
Orielly's auto parts (misc supplies)
Home Depot spray paint
Window Driver side rear 40" x 12"
Front floor liner from FAMVAN
Fat Mat sound deading material x2 rolls
Window Passenger side 40" x 26"
Rear sill trim piece
Sliding door sill plate
Rear doors weather stripping
Home Depot Frost king Insulation
Passenger and driver side seat belts
Old 07-29-2013, 01:26 PM   #10
Re: SOCAL build
Rear doors with fresh paint\Fat-Mat and weather stripping
