Old 02-14-2012, 12:34 PM   #1
Gnarvan's Avatar
Sway bars
I called Roadmaster this morning to get some more information on their Active Suspension system. During the conversation I asked them if the vans in the video with the before and after instillation sequences were equipped with sway bars. He said no, they were just stock off the showroom floor vans. I was a little surprised with this. I thought most new vehicles came with sway bars. Does anyone know if new vans come stock with sway bars? Are they an option item or maybe aftermarket?
John
Gnarvan 1992 E350 Clubwagon
2003 BMW R1150GS-Adventure
2013 BMW R1200GS-Adventure
Old 02-14-2012, 02:27 PM   #2
Re: Sway bars
Aren't the vans in the videos Dodge vans? If so, Dodge hasn't made passenger vans (Sprinters aside) in quite a few years (since 92?, 94?). I would think any recent vehicle would have sway bars.
Old 02-14-2012, 03:00 PM   #3
Re: Sway bars
Every Ford van I've looked at has a front anti-sway bar, and no rear bar.
Old 02-15-2012, 04:01 AM   #4
Re: Sway bars
+1 ! Even though most stock anti-sway bars are terrifically undersized for much more than the stock chassis---adding almost anything more load wise really pushes them to their limits of performance.
Most every stock suspension bushing for the movable parts are of such soft material they're largely ineffective even when brand new---after a few years they're typically degraded enough they're almost useless.
Rear bars are an option on most chassis unless they've been special ordered by the original owner.
Old 02-15-2012, 03:32 PM   #5
Re: Sway bars
My 2011 Sprinter has a rear sway bar, as part of a suspension package option. On my crawls underneath, I did not pay close attention to whether it had a front sway bar. Will look next time.
bluesprinter is offline   Reply With Quote
Old 02-15-2012, 05:42 PM   #6
Re: Sway bars
My 2009 ford E350 quigley came with a front sway bar. I added a Hellwig rear sway bar.
tuffcap is offline   Reply With Quote
Old 02-15-2012, 09:40 PM   #7
Aldercrest's Avatar
Re: Sway bars
My 2002 EB had a front sway bar, no rear, and aftermarket rear Deaver springs when I bought it. Adding a Hellwig rear (anti-) sway bar really helped.
2002 E350 EB - Voyager top - 7.3 - Quigley 4WD
Aldercrest is offline   Reply With Quote
Old 02-17-2012, 11:00 PM   #8
Re: Sway bars
The guys at the 4x4 shop that fubar'd my shock install SWORE that I would die without a rear swaybar. Not having one has never been an issue... including driving 14 hours with one shock.
Old 02-18-2012, 09:12 AM   #9
twogone's Avatar
Re: Sway bars
... so did you put one in?
'95 SMB E350 Quigley 7.3
https://www.taylorarts.com
Old 04-06-2012, 04:05 PM   #10
BIGVANS's Avatar
Re: Sway bars
I also agree with Mike, every new Ford van I've seen has a front anti-sway bar, and no rear. I had a Hellwig rear on my last van and I saved it to install on my current van. I never needed it or missed it so I never installed it.
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
