Old 06-29-2011, 04:42 PM   #1
swivel seat
Starting a build on my 2011 E250, will be slow going, first thing is a swivel on the passenger seat, any reccomendations, tips... thanx. Dave
dz3866 is offline   Reply With Quote
Old 06-29-2011, 06:09 PM   #2
dhally's Avatar
Re: swivel seat
Yes you will need a "Torx Plus" T55 wrench to remove the front screws. I got a Torx T55 and it is a loose fit although it works.
If you are considering sound deadening the cab floor the time to do it would be while the seat(s) are out.
2009 E250 RB 5.4L "SilVan"
Old 06-30-2011, 07:32 AM   #3
Re: swivel seat
thanx, I will get that wrench, so it looks like I will need to get longer bolts when I add the swivel base ?
Old 06-30-2011, 09:35 AM   #4
dhally's Avatar
Re: swivel seat
The stock bolts should work. Also might note that the back of the seat is held down by nuts which are metric. Can't remember the wrench size. Pretty much all the fasteners I've found on the van so far are metric except the battery terminal clamps.
Old 06-30-2011, 10:52 AM   #5
Re: swivel seat
Wouldn't those be 13mm?
Old 07-04-2011, 11:49 AM   #6
bettyford's Avatar
Re: swivel seat
This is where I bought mine it was a piece of cake to install but it did raise the seat about 2in.
http://www.discountvantruck.com
Ron
Going where most dont
"one day at a time"
