02-17-2016, 07:10 AM
While this is a cool idea and definitely a simple install, the cost of this tank is ridiculous at 1,798.00, especially for the capacity. I would rather just install a 40 gallon aft axle tank and remove the 35 or leave it and have a switch on the dash to go back and forth between the two. I never liked the one tank draining into the other concept, but loved how you could just switch from one tank to the other on older trucks.
02-17-2016, 08:53 AM
^What he said
Cutting out the spare tire carrier, and adding the cutaway rear tank, would be a fraction of the cost of the "spare tire" tank. Also, transfer tanks (like the Titan) won't work on the newer vans. The computer doesn't like seeing the fuel level go up while driving. If I understand right, it runs a calculated fuel level for DTE, and will still start dinging at you to Fill Up NOW once you've used 35 gallons, regardless of fuel level in the tank. So, you'd want to set it up as an aux tank with a selector valve instead.
02-17-2016, 09:16 AM
Aerotank 45 gallon is about $950 if I remember right. They also make the rear spare tank like this one for about 1150.
02-17-2016, 10:14 AM
Oh I like the aerotank aux so much better. I like the stealth fill up.
AeroTanks - Make Stock# VAN40aux
Has anyone set it up with a selector switch?
Of course it says 'diesel only' I'm guessing that means I'm on my own for plumbing.
Quadvan promises 100% legit gas tank install but what does that mean? Do I get some kind of paperwork? Has anyone one had the gas tank police taze their grandma?
Does anybody know a place that does installs (transfer flow, aux, etc) on the east coast? Wife does not love this epic quest. I must appease her. She is more than happy to bring this up much much later.
02-17-2016, 10:37 AM
Hi,
The diesel only label is for much more than gas usage means you have to do your own plumbing. All the manufacturers moved their gasoline tanks ahead of the rear axle some time ago. Installation of a gasoline tank behind the rear axle where none existed previously is bound to draw the ire of your insurance company should you have a claim related to that tank leaking or causing a loss.
There is a note on the above listed tank maker's website that you must also have a certain hitch rating installed. Again collision protection is their mantra. Diesel fuel is much less likely to ignite if the tank is breached.
Also the evaporative emission canister only has so much capacity to store fumes between engines firings so that system should be twinned in order to stay above board. Frankly, copying a 1993 or so Ford pickup truck twin tank plumbing setup would probably keep the computer happy.
I believe the selector valves in those vehicles can stand the higher pressure injection systems require.
Let us know what you build. I can't stand only carrying 5 hours of fuel.
Regards,
Gavin
02-17-2016, 11:58 AM
Originally Posted by Pntyrmvr
Hi,
Regards,
Gavin
Ah I see, thank you.
So I'm back to regretting not ordering the 46g transferflow in the first place.
Been kicking around the idea of just building a basement in the back and just putting long flat gas cans in there when I need them. To me that is obviously less safe and less convenient, but hey isn't that's what red tape is really about?
If I bought that gas tanks in the back are always bad I'd just switch to the basement and live with the range, but I seem to remember a whoopla in the press (after pickups switched to side tanks) about exploding trucks and dead T-boned pickup owners.
They couldn't make an official exception for any gas tank with a class 5? *sigh*
Trying to think for yourself seems to be downright illegal these days. IANAL and all that.
Guess my next step is a quote from Quadvan.
Wish there was some kind of full service custom van 4x4 shop east of the Mississippi.
02-17-2016, 12:25 PM
Stupid part is it appears to be legal to haul gas cans on your rear bumper, but not in a factory style setup behind the rear axle.
Custom van shop for 4x4 east of Mississippi? Quigley is in Pennsylvania. Don't know about tank installs though. Call the tank manufacturer and find out.
02-17-2016, 12:38 PM
I'll try Quigley and Sportmobile east, but I have my doubts.
02-17-2016, 02:45 PM
Originally Posted by carringb
... Also, transfer tanks (like the Titan) won't work on the newer vans. The computer doesn't like seeing the fuel level go up while driving. If I understand right, it runs a calculated fuel level for DTE, and will still start dinging at you to Fill Up NOW once you've used 35 gallons, regardless of fuel level in the tank. So, you'd want to set it up as an aux tank with a selector valve instead.
VivaLaVida have a transfer tanks and I haven't noticed any issue filling the main tank from the auxiliary one. The gage rises slowly during transfer and DTE seems to be recalculated. However, I also installed a manual selector valve in case of leak in one of the tanks...
