01-14-2013, 08:49 AM
Re: Fiberine Top Yellowing?
Herb, sold the old top couple months ago. Wish I had that quality on my current top.
Andrew, considering a few options for a solution. Both parties (Fiberine & TechAmerica) have mentioned the UV stabilizer issue but neither will make a statement about wether my top was produced without it.
I have quotes to paint the top from $1200.00-$2400.00 which is what really needs to be done. Both paint place state they have never seen fiberglass yellow this quick. Everyone who has seen it seems to think there was a problem with the original pour. I may just have it painted and work on a remedy with them after the paint. I have been holding off this whole time hoping they would do the right thing.
It irritates me every time I see the van now.
01-14-2013, 11:05 AM
if you where in chicago i would paint it for free for you...dam $1200to$2400.
01-14-2013, 04:12 PM
That is to paint the whole van and not just the top right?
01-14-2013, 04:22 PM
Just the top. Apparently it has to go into a semi truck paint booth because of the height.
01-14-2013, 08:43 PM
Why not rhino or other spray. I really like what SMB put on mine (Raptor) and it cleans very easy.
01-14-2013, 11:27 PM
I had Line-X in El Cajon spray my penthouse and roof over 2.5 years ago and the color still matches the Baja Tan perfectly. I would expect white stability to be similar with the UV option. They had no trouble with the height since they do not need to spray in an enclosed booth. I highly recommend them and went back to them with my Comanche for some work. Of course you have to accept the texture and weight but it solved so many problems it was a no brainer for my situation.
Pat
01-15-2013, 06:04 AM
You could always go with a different color if you're concerned about it not matching. Personally, I always wanted the factory two tone paint option available on the vans, but it is/was only available if you ordered some number (6-12 ?) of vans at the same time, all painted the same. The second color was below the body line.
01-15-2013, 01:49 PM
Your experience doesn't give me a very good feeling about Fiberine, to put it mildly. I'm sorry you're having to go through it, and I understand how it can tarnish your entire van experience.
I can't speak to the various Line-X type products, but if you want a shiny, matching finish (like the gelcoat *should* have been), then I would suggest a good, two-part LPU type coating. Either something like Awlgrip (polyester) or Awlcraft (acrylic). These two variations are also made by other brands (Sterling, etc.). The polyester variant tends to be harder and shinier, but less easily repairable or buffable (OTOH, may not need buffing for a looong time), whereas the acrylic base is more easily repairable or buffable but less super hard/durable. They're both comparatively hard paints (really "coatings") though. Both variants are often used to paint boats that were originally gelcoated.
I had/have been thinking about getting a fixed high top for my SMB (was drooling over the one you had for sale but I have an RB), and Fiberine would have been one of the top contenders. But I don't like it when someone seems to weasel out of a problem by using the "letter" of the law vs. the spirit of it. Sad.
01-15-2013, 03:26 PM
Great ideas Herb and Viva, just visited a Line X shop and they quoted around $2000.00 to do the top.
Viva, there has not be one good thing about my experience with Fiberine. They did help with the repair of the leaks with the windows and top which was within my 90 days they said I have. I still have yet to see the 90 warranty written anywhere on their website or my paperwork. It may be there but I can't find it.
Even one of the windows that's in the shell is a different color than the others. Their response was they don't have control over parts they buy from others??? The caulking job was sloppy around the outside. The installation was a nightmare at their facility. The screws they used on the inside separated the shell and van top leaving gaps all over the place. I'll post all the photos I have here shortly.
Just got of the phone with TechAmerica a few minutes ago just to clarify that they supply two types of GelCoat to Fiberine. As mentioned above one with the UV stabilizer in it and one without. She again stated the non stabilized gelcoat will yellow outside. I can only assume they poured my top with the wrong barrel.
As you mentioned Viva there is the letter and the spirit. We make mistakes at our company and we do everything we can to take care of it. I don't want anything free, just what I paid for.
They stated in the beginning I did not need to paint it as they made a quality white GelCoat.
I think I have enough written correspondence to take it farther legally.
01-15-2013, 08:33 PM
#20
