Old 02-06-2012, 11:34 AM   #1
VersaTie Track How you mounting it
getting ready to order 32 ft of track and was wondering how you are attaching it to the insides of the van.... since most of the walls you can get to the back side to install the nuts to the mounting bolts.... show pics.... thanks for the info...
MrWicked is offline   Reply With Quote
Old 02-06-2012, 10:56 PM   #2
Bones_GSXR's Avatar
Re: VersaTie Track How you mounting it
I used the type 4 track and cut my bedrug to fit in the floor. If you are using wheel chocks you need no wall mounted tracks at all. if I was going to mount to the wall I would have to put steel plate behind the wall and mount that at the ribs then use type 1 or type 3 mounted through the wall. You could use type 4 but then it out not use the wall panel. if you use the right thickness you could drill and tap the steel and mount right to it.
Old 02-07-2012, 02:56 AM   #3
AndrewST's Avatar
Used rivet nuts to install them on the floor and walls
Old 02-07-2012, 09:11 AM   #4
we have thought about the blind nut or nut serts just wantoing to see what others are doing....
i will mostly hauling cargo in containers so motor bikes....
Old 02-08-2012, 01:46 PM   #5
dhally's Avatar
If you want a really strong mount, how about something like this? Attach to walls with 3 self tapping screws?
Or maybe just drill some extra holes in the track and use lots of screws.
2009 E250 RB 5.4L "SilVan"
Agnes
alta825
Sporty
BusTalker
