Cabin Spot Lights
The cabin spot lights were purchased on Amazon from Dream Lighting. They have individually push button switches on them and are powered by my Goal Zero system.
Here are the specs from the seller:
No mounting hardware included.
Our nickel brushed reading light with crystal lampshade is designed for interior RV, caravan, camper trailer, yacht, boat, etc. The stylish appearance makes it popular and hot sale. Please imagine when the blue light meets the crystal lampshade, what a beautiful decor you could get! Adapting high quality LEDs, warm white lighting is bright caused no eyestrain, soft blue lighting is elegant and fantastic. No need to worry about the power consumption would be high. Our LED reading light just consumes 1.9 watts thanks to the efficient LED chips. OK, time to try our honorable 12V LED reading lights!
Two-phased Lighting:
1. Press the button for Blue lighting.
2. Press and hold the button to activate the Warm White lighting.
Specifications
Volts: 12V DC
Wattage: 1.9W
Current Draws: 140mA
Lighting Color: warm white and blue
Lighting Angle: 120 degrees
Brightness Level: 100 lumens
Height: 2.5inch, Base Diameter: 2.3inch (Please refer to the picture with dimensions)
Features
A. Swivel joint provides adjustable lighting angle and direction
B. Nickel brushed and acrylic lampshade not only provides decorative effect but also distribute soft and even light output
C. High quality LED chips have stable and efficient performance.
D. Low power consumption at 1.9 watts to save energy
E. A programmed switch is equipped.
F. Surface mount design is for easy hook up and neat finish after installation
G. LED is a reliable lighting source which characterizes long life span.
