Well what a GREAT WEEKEND camping with my crew!!
Stayed nice and warm in the van snuggled under blankets...with the top down the medium sized little buddy on low kept it t shirt comfortable inside when it was 20* and lower at night!!
We did get some backroading in and a nice water crossing on a road I know...about 10 in deep...2wd van laughed at it!!
I even got a chance to smooth out those cupped tires I rotated to the back (childish burn out)
Many things worked FLAWLESS..and even some more were better than planned...the bed is wider than what we were used to in the old truck and being lower (no climbing) it was easier to get in and out and turned around on in the middle of the night..(potty)
The skylight was perfect for stars and letting the brite moonlight in...and not being too brite when the sun came up!! Ill be glad when I get the removable sunroof in its place and I can open it or pop it out on nice nights (with a screen so no bugs get in)
Notes..
Need to put lights in cargo area on main overhead switch..not enough light at night to get ready from just the front light.
Need to get the kitchen stuff in a rear mounted box for easier access...
Need to connect the secondary start battery and the house battery..it was too overcast too many days and the 100ahu battery wasn't up to running the fridge and the inverter all night..(it did get cold inside so I'm sure battery suffered but it was only at 11.7 volts at sundown..need to add capacity and ability to charge from alternator on overcast days..one wire and an isolator switch will fix that!!)
Need to add more clips so I can hang divider curtain across side door and front seats to minimise heat loss thru upper doors direct metal to outside and Windows.
Spin passenger front seat once at camp..adds more room in back and would make it super comfy for 2 or more adults to be inside warning up.
I started the rear door flip down shelves today...might as well add inner door storage for recovery and kitchen stuff..and hung some straps for headlamp bag, waterproof foldable bowl and misc stuff..
Pictures!!
Mohican state park campground B
Abandoned bridge
Abandoned smoke house
Playing submarines
White smoke burn out (7.3)
Sent from my VS987 using Tapatalk
