The Van Compass NCV3 2007+ 2500 Sprinter lift kit is in production and will be available towards the end of September.
The Striker bolt-on suspension lift system provides clearance for up to a 33” tire allowing for higher ground clearance off-road helping to avoid obstacles on the trail. The Striker system retains the stock vehicle suspension and rake keeping the OEM vehicle geometry, payload rating and ride quality. All of the suspension lift system components are constructed of high quality materials here in the USA and are powder coated for durability and corrosion resistance.
INCLUDED COMPONENTS:
Front 2.0” strut spacer - 1/4” hot rolled steel
Front 2.0” subframe drop spacers - 4140 heat treated chromoly
Motor mount 2.0” lift spacer - 3/16" hot rolled steel
Transmission 2.0" lift spacer - 6061 aluminum
Steering shaft extension - 4140 heat treated chromoly
Low pressure power steering hose extension
Front and Rear brake line relocation mounts
Rear 2.0” lift block - 1/4” hot rolled steel
Rear sway bar links - 11/16" x .120 DOM and 3/16" hot rolled steel
Rear lower shock mounts - 1/8" hot rolled steel
Rear bump stop drop brackets - 1/8" hot rolled steel
All necessary hardware
Product
Link
Link to
Front Installation Instructions
Link to
Rear Installation Instructions
Thanks to everyone for the support with our other products. It has made this new lift kit possible.
When the 2wd van is lifted, our 4x4 Engine skid plate bolts on perfectly!
