Old 07-21-2020, 11:47 AM   #1
New heavy duty scissor jack
This may be of interest to forum members who are looking for a jacking solution. This jack can lift from 5 in (125 mm) to 17 in (440 mm) has an effective lifting range of 12 in (310 mm) Heavy duty construction, reinforced in all the right places.
It has an optional height extension as shown.
For more details see youtube video here https://youtu.be/44YXAVZnAQc and here https://youtu.be/vWyXTwpqcY4
Jackmaster is offline   Reply With Quote
Old 07-13-2023, 03:55 PM   #2
Wickedwagens's Avatar
What do those run with the extension?
Wickedwagens is offline   Reply With Quote
Old 07-14-2023, 12:34 AM   #3
It is soon to be available in the US, shipment is due to arrive by end August.
Price will be about USD130 delivered to your door. This will include the height extension, ratchet bar, crank handle, bag and accessory organizer.
Final price can only be determined once consignment is landed.
Old 07-14-2023, 04:21 PM   #4
Can it be operated with an impact driver?
Nrobert10 is offline   Reply With Quote
Old 07-15-2023, 12:35 AM   #5
We have customers that use impact drivers, but we don't know what the long term effects will be with frequent use. So far there have been no failures or complaints. A high-torque cordless drill driver works like a charm.
The jack has been designed for extensive use and utilizes high quality components. It is NOT made in China
Old 07-15-2023, 09:03 AM   #6
Jeffrey's Avatar
I'm in. contact me.
Old 07-15-2023, 09:25 AM   #7
Originally Posted by Jeffrey View Post
I'm in. contact me.
Extra Heavy Duty Construction
2 Ton Rating
Effective Range of travel/lift : 310mm/12.2 Inches
Min Height: 130mm/5.11 Inches - Max Height: 440mm/17.32 Inches
Min height with optional height extension: 280mm/11 Inches
Max height with optional height extension: 590mm/23.22 Inches
Height extension is 150mm/5.9 Inches high
Weight of height extension 1kg/2.2Lbs
Weight: Jack plus crank handle +-9kgs/19.84 Lbs
Dimensions: 560mm x 130mm x 130mm 22 inches x 5 inches X 5 inches
Crank handle with integrated universal joint included. Length 500mm/19.7 Inches
Ratchet bar included. Weight 0,7kg/1.57Lbs length 350mm/13.77 Inches
Notification will be issued should any specifications change.
Old 07-15-2023, 11:21 AM   #8
gahamby's Avatar
I'll have to compare dimensions with the squirrelly jacks in the car trunks. Looks nice.
'07 GMC 2500 6.0
Old 07-16-2023, 12:40 AM   #9
It does come with a bag, so you can place it anywhere.
Check out gortech.co.za for pics, specs, reviews and videos.
Tags
heavy duty jack, jack, scissor jack
Agnes
ranchero
Betsy
darryldickie
