Old 08-30-2012, 09:33 AM   #1
1993 Sportsmobile $14,000
No affiliation, other then I wish this would have been available several months ago when I was shopping!
http://sfbay.craigslist.org/sby/rvs/3228954241.html
1993 Ford E350 Sportsmobile RB van conversion
111,000 miles, 5.8 (351) engine, E4OD overdrive transmission, Dana 60 full float 4.10 rear axle
2WD (not 4x4) with 2" suspension lift
Power windows, locks, cruise, tilt, keyless entry, remote starter, tow package
Interior is custom built, all real wood (not fiberboard), with a layout similar to an RB50
Penthouse top in perfect condition with color-matched bedliner coating and optional bed
Large in-floor storage compartment
LOTS of new parts and upgrades:
KYB Monomax shocks, all new steering linkages, steering stabilizer
Aftermarket swaybars front and rear
New aluminum wheels and tires (BFG Rugged Terrains)
Chassis battery and seperate deep cycle coach battery
100 watt solar panel and charge controller
Shadyboy awning (never used) opens to 10'x6' with reflective sun coating
Upgraded larger radiator, new water pump, all new hoses, thermostat, belts
All new tune up parts, plugs, wires, cap, rotor, filters, etc. New timing chain (since I had the water pump off anyways)
Dual heavy duty transmission coolers
Rearend bearings replaced during new gear install
3" dynomax mandrel bent exhaust system
Fresh water sytem holds 10 gallons and has grey water holding tank Electric flush PortaPotti included, only used on 1 trip
Separate rear AC and Heat
Rear seat (removable) has 2 lap belts
Dometic/Waeco high efficiency electric fridge with Danfoss compressor
Nice stereo system with Pioneer deck that has Ipod control, Pioneer amp, Infinity speakers, and a JL Audio 10" subwoofer built in to the cabinetry
It runs and drives great, gets 15-16 mpg freeway
Ready to use as-is, but there are a couple things that need some finishing:
1. The water tank is mounted, but exposed inside. I was going to build a cover to hide it, but never did.
2. The rear seat needs some hardware installed (bolts and brackets, all included) before someone can use the seat belts.
That's about all it needs.
Registration is current and has a clean title
Smog included
I know there is more that I forgot to list, I need to sell to purchase something larger for our growing family.
$14,000/obo
(408)
438-3884
joearlo is offline   Reply With Quote
Old 08-30-2012, 11:48 AM   #2
Sweet deal on a nice ride! Good luck!
