Old 06-13-2014, 10:31 AM   #1
gnty's Avatar
1996 4x4 Dually Diesel Van High Top $7500
No mine. Quite interesting.
http://providence.craigslist.org/cto/4517252346.html
2005 E350 EB 4x4 6.0 Super Camper HT
2005 E350 RB Passenger 4x4 6.0
1995 Bigfoot 20' Class C 4x4 7.3
gnty is offline   Reply With Quote
Old 06-13-2014, 10:36 AM   #2
Re: 1996 4x6 Diesel Van High Top $7500
I don't believe that's a 4x6.
Wonder what the inside looks like.
Old 06-13-2014, 12:30 PM   #3
MrHenrietta's Avatar
Re: 1996 4x4 Dually Diesel Van High Top $7500
Wow that thing is quit interesting.. Seems like a hell of a deal regardless of what the interior looks like.
2003 7.3 UJOINT 4x4 SMB
MrHenrietta is offline   Reply With Quote
Old 06-14-2014, 05:59 PM   #4
Not sure I trust the dually setup, I think I'd swap a real dually axle in there just to be on the safe side. Otherwise it's quite a van.
Old 06-14-2014, 07:57 PM   #5
A '96 will be a full float, probably a D70. Extended wagons got the same brakes as the cutaways, which means 3.5" shoes vs the regular 3" shoes.
I did the Arrowcraft hubs on mine. Dana doesn't specify a max offset for the full-floats. I had the bearings out at 265k to inspect them, and they still looked new so they went back in. Arrowcraft upsizes to the studs so they are good for 10K even with lugcentic outer wheels.
I do plan on upgrading mine to an E450 axle (or maybe F450) solely because I'm way over what the D70 is rated for. Loaded weight with the trailer puts me at nearly 11,000 on the rear axle. But, its held up just fine, other than that one time I split the diff carrier (rough landing, not on purpose that time).
Old 06-14-2014, 10:45 PM   #6
Wow! It's a 7.4 diesel! Must be a One-off thing Ford did.
Dorothy the Van
ohmbaby
Rosy
Isever
