Old 10-15-2019, 05:57 PM   #1
2006 Ford E-350 6.0 Diesel 4x4
https://sacramento.craigslist.org/ct...000418519.html
Speedometer reads 90284. All work below
was done approximately 10,000 miles ago.
J&K engines
6.0 Power stroke long block includes complete
rocker assemblies, heads with ARP Head Studs,
block with rotating assemble.Stage 2 colt cam,
High rev valve springs, new low pressure oil pump
complete assemble with front engine cover
BULLET PROOF
Cooling System upgarde Kit,Fuel pressure kit
High pressure oil pump, Oil cooler system, water pump
7.3 clutch fan assembly
FORD
Injector nozzle assembly 8
Glow plugs,& wire harness
Turbo charger and down pipes
Power steering pump
Hoses and belts
Torque converter
Dana 60 axles
4:10 Dana true track front and rear
front axle completely rebuilt, WARN hubs,
Crossover steering, drivelines by Drive line Service
* U-JOINT Offroad Four-wheel-drive conversion kit
* Wheels fuel beast 9 x 17
* Toyo M/T 35x12x50 R17
* ALUMINESS Front bumper with brush guard
* ALUMINESS rear bumper with brush guard
* Deluxe box sealed, rotoXpax 3 gallon fuel can
* Spare tire mount
* 12,000 pound Smittybuilt wench synthetic rope
* Factor 55 Prolink&2.0 hitchlink
* Bushwacker Fender flares
* Aluminum top rack
* Custom upholstery, heated seats, headliner, Dash, door panels, passenger seat swivels, spray foam insulation, Dinamat doghousing, front floor, husky liner front floormat.
* Bed platform with 2 forward facing locking drawers 22x19x12, 2 rear facing drawers 48x19x12 500 pound slides, 2 side compartments, 1 front compartment 22x22x12
* Bumpers and interior cabinets all keyed the same
* Auxiliary diesel heater
* ARB twin cylinder air compressor plumbed to front and rear bumpers along with Anderson jumper cable plugs
* ARB 60 quart refrigerator freezer
* Flush mount locking gas cap
* Power windows, mirrors, Blaupunkt radio, back up camera, navigation
* Redarc Tow-Pro Elite Trailer Brake Controller
Tandem Axle Custom Trailer
* Deck 67”x124” 7/8” composite plywood
* Box 69”x42”x25”1/4” composite plywood
* 2x4 120 wall main frame, 2 1/2” x 2 1/2” x 3/8” tongue
* off road Max Coupler Multi axis
* Interior and exterior light, Blue Sea battery shut-off, Uptima yellow top battery, illuminated keypad rocker switches, fire extinguisher, Camplux hot water heater
* There are 3-2” receiver's on rear of trailer sufficient to tow rig out backwards. Would work for motorcycle rack or firewood
* Fuel beast wheels 8 x 16 Cooper LT 265 x 75R16 tires
* 23 gallon water tank with water pump
* 23 gallon fuel tank, GPI G8 transfer pump, hose is rolled up in rear fender step
* Fulton tongue jack
* Two rear leveling jacks
* Side storage tube 8' x 8”, great for awnings, poles
* All lights are LED, fuse protected at trailer
* Aluminum ramps
* Four wheel independent Timben axles easy lube
* Rear axle has breaks
* Boxes and fueling station all keyed the same
* 4400 pound capacity GVW, trailer weighed 1740
* Less than 500 miles
* Comes with set of 4 Max wheel nets and tie downs
This is a custom built trailer for off-road no corners cut should last for decades.
kennyboyce@me.com
916-804-0945
ksportsmobile is offline   Reply With Quote
Old 10-15-2019, 06:03 PM   #2
Dang sweet rig! That won't last long at that price.
Just curious but how do you like the stage 2 cam?
2011 VW TDI Golf for hwy fun
Old 10-16-2019, 08:25 AM   #3
Twoxentrix's Avatar
I like the whole package! GLWS
TwoXentrix
"AWOL"
Old 11-12-2019, 04:52 PM   #4
Bump with new price $
