Old 09-15-2019, 10:32 AM   #1
Big van
Well it's big if you need more space in a van. No affiliation.
https://www.ebay.com/itm/Off-Grid-St....c100009.m1982
This rig is not for the faint hearted. It’s a 2006 Freightliner MT45 Step Van with a 5.9 Cummins diesel engine. 28,000 miles and runs great. CA smog exempt. Originally this was built for Homeland Security as a S.W.A.T. rig by LDV. (ldvusa.com) I purchased and built out as a fully solar powered stealth van. Not real pretty on outside, I purposely did not paint it because I wanted it to appear as a contractor's rig when boondocking. It could be buffed for more shine if desired. There are so many things to list so I will have a YouTube video up if you are interested in buying. It can be lived in full time or a weekend camper. The 9.0 cu ft refrigerator/freezer was very expensive and designed specifically for solar power. It runs full time and doesn’t impact the power at all even after multiple overcast days. Check them out ecosolarcool.com. The 480-watt solar is a 12-volt system with 4 batteries and works excellent. I will try to list everything I can. Message me if interested but only if you are actually interested in buying. I will add as many pictures allowed but have lots more. For Sale locally so I reserve the right to end if it this add if it sells.
NOTE: One of the gauges (fuel/temp) works about ½ the time, I’m sure someone with some electrical skill could fix. I only drive about 10 miles a day so it doesn’t bother me.
TRUCK:
Freightliner MT45 step van
5.9 Cummins diesel
Allison automatic trans
Heavy duty hitch
Electric trailer brakes
Aux power at rear for a winch or any other device needing power
Zip Dee awning
Several exterior 110 outlets
Shore power hook up
Large rear storage compartment
Extra storage in water tank area
Strobe lights
Electric mirrors
Power steering
Power brakes
6 new tires a few months ago
New front brakes
Tilt wheel
2 dash fans
Rearview camera & monitor with sound
Detachable face Bluetooth stereo with USB plug
INTERIOR:
83-inch ceiling height
Ceiling insulated with 2-1/2 inches spray foam
Walls insulated with pink
10-1/2 ft. of countertop space
Extra-large sink
Pull down faucet
propane stovetop with 3 burners
1 20 lb. propane tank
6 gallons sink waste water
8 gallons drinking water
30-gallon water tank
Pull out spice rack on hinges
Over 20 ft. of overhead cabinets
Large pantry/storage
51-inch seating area
Cedar lined storage under seat
9.0 cu ft solar refrigerator with freezer
Rotary microwave oven
Ecotemp tankless hot water heater
30x30x74 closet which converts to shower stall with cassette style waste water (no septic)
Removable platform bed over garage area
Bed is single size mattress with room to convert up to queen size
Can move bed to lower height or can use a bunk bed on lower mount
Bed(s) remove in minutes and are on E track
2 fantastic fan vents
King Jack directional HD TV antenna
LG 24-inch smart TV on full adjustable mount
HDMI wall port to connect devises to TV
Roof air conditioner
Large garage area under bed with E track on walls (lots of e track accessories included)
POWER:
8,000-watt Onan generator (recently serviced and runs great)
3-160-watt mono solar panels, 480 total watts
3000-watt pure sine inverter
2 battery chargers run with generator or shore power
4 AGM Deka valve regulated batteries
Shore power hook up
Exterior 110 outlets
BroncoHauler is online now   Reply With Quote
