If the description is accurate, the parts alone are easily worth the price.
I wouldn't pay that much for it. 250k is pretty much the end of that motor. I suspect by "oil pump" they probably mean HPOP. Tearing that far into a 6.0 with that many miles, you're probably better off just buying a Ford reman. By that age, you'd probably be earning yourself a new engine wiring harness because any invasive work will probably introduce new electrical headaches. And of course bad HPOP often means new injectors.
The 5R110 go for about $350 at the wrecking yards. It only has a semi-float rear end which also go for about the same price. So I guess once you scrap the rest of the van, you could make a little money but it has headache written all over it.
