Old 10-17-2011, 03:03 PM   #11
Re: Dually thoughts?
Originally Posted by blair
Holy cow, that's a lot of weight. I would have to guess that my tongue weight might be more than i think.
thanks for the education.
Boat trailer can be as low as 7% tongue weight. The setback axles allow for stable towing with less tongue weight. Toy Haulers are the worst. They can exceed 20%.
Old 10-18-2011, 09:57 AM   #12
tdgsmb's Avatar
Thanks for all the responses.
Since I do encounter mud ruts regularly now, and intend on using my SMB for skiing (slush roads) - I think I will skip that dually and continue the quest for the right SMB.
Thought about switching out the dually for a single, but not sure this makes sense. Sure there is someone out there in the same situation as caringb with a need for a dually setup.
tdgsmb is offline   Reply With Quote
Old 10-21-2011, 11:49 PM   #13
I have had big, heavy campers on 4wd pickups in past years? Even with overloads and rear air bags, the pitch and sway on mountain roads was a problem. Now I have a class B+ with dually rear....and it drives so much better on winding roads. I feel much more in control and can take turns faster. That helps with steeper uphill climbs. So that may be the biggest advantage to the dually.
I also have a Dodge 2000 SMB.
gbail is offline   Reply With Quote
Old 10-22-2011, 09:36 PM   #14
Why are dually's bad in mud ruts? In my experience oddly narrow axles do great because the ruts are more common width and so the narrow axle draws the opposite tire out even as the other goes deeper. I would have thought dually was the same- getting traction either by being wider than the rut or drawing over. Not true?
Old 11-02-2011, 04:47 PM   #15
I won't say traction is any worse, but the rear end sifts side to side more, as if the tires are fighting eachover for who gets to be in the rut.
Old 11-03-2011, 11:08 PM   #16
Which in my experience means you go forward... it's sitting nice and quiet in the rut that gets you stuck.
Hmm, I'd as somebody else but all the jacked dually pickups around here are show not go, and they wouldn't know.
