Old 03-03-2016, 07:40 AM   #1
Econoline with Fiberglass Body
Weird looking.
https://losangeles.craigslist.org/la...454622566.html
2005 E350EB, 6.0, UJOR 6" lift, 35" tires and more.
Zuma is offline   Reply With Quote
Old 03-03-2016, 09:54 AM   #2
That is the second one that I have seen posted. The first was white.
"A straight line may be the shortest distance between two points but it is by no means the most interesting". Jon Pertwee as Dr. Who, The Time Warrior.
Old 03-03-2016, 09:59 AM   #3
rallypanam's Avatar
I've always really wanted to like these, but I can't quite get over the looks..
Old 03-03-2016, 11:24 AM   #4
Just in case you've ever *really* wanted to drive a giant tangerine.
Good luck repairing it if someone accidentally bumps into you...
scotticus is offline   Reply With Quote
Old 03-03-2016, 06:39 PM   #5
Actually, unless you really make a big mess of a wreck, fiberglass is not that bad to repair. I have knocked a few holes in boats over the years and just matching the outer color is the hardest part. I worry more about collision durability and passenger safety with an all fiberglass van, for example the SMB Classic under development. At least it still has the Ford front end.
2008 Ford E-350 Quigley 4x4 V10 Gas - 144,000 miles
Van Weight 7,800 pounds, added one rear leaf to even it out, BFG AT KO LT265/70R17 E Tire press 50psi seems to run best at my van's weight.
Old 03-03-2016, 07:37 PM   #6
I can see this on 35's 4x4
polishadam82 is offline   Reply With Quote
Old 03-03-2016, 08:11 PM   #7
Looks like a pregnant guppy.
www.arctictraveller.com
Old 03-03-2016, 08:27 PM   #8
Lots of those for sale here in Alberta. I see them every couple of weeks. I really like em... Fiberglass won't rust, is water tight, easy to repair... These ones often have a sunroof panel in them.
Would make an awesome camper if you did a 4wd conversion and only needed seating for 2.
ert01 is offline   Reply With Quote
Old 03-03-2016, 09:14 PM   #9
JackTuppVan's Avatar
Aerocell SRW 4x4 fiberglass body manufactured by UNICELL Fiberglass van bodies, van bodies
2007 E250 Super Duty cargo
1988 Toyota Van 4x4 5-spd
Old 03-03-2016, 10:26 PM   #10
now that is cool
