Old 11-09-2017, 03:07 PM   #1
MountainBikeRoamer's Avatar
FS - Extensive Build: Quigley Chevy EB
Been intrigued as heck with this listing!
Seems it's a lot of equipment (and van!) for the money.
(Still not sure if it's actually a Sportsmobile build-out or not, but it sure looks comparable. Also still not sure if he lists the actual mileage on the rig anywhere in his manifesto-length description, but the van looks in clean/solid shape all around.)
4 Captain's chairs + 4WD + Well-maintained/clean rig = worth a look....
No affiliation!
Campervan, 4x4 Quigley, Self Contained Chev E2500, ClassB - $45000 (Brookline)
https://boston.craigslist.org/gbs/rv...358028716.html
Copy this link into your browser for more detailed pictures EBay rejects full links so, put in the beginning of the URL, then //drive.google.com/folderview?id=0B0Q4sme_2UUTcHNvSzBsZ2diNU0 Also, this van has the popular RB-50 layout from Sportsmobile //sportsmobile.com/preowned-sportsmobile-texas-inc/
Full self-contained bugout 4x4 Class B, a Season Campervan
Custom metallic pewter paint with matching fiberglass running boards.
Power heated mirrors, rear window defoggers and daytime running lights.
Extreme weather insulation package.
Dash mounted/ Adjustable Firestone Ride-Rite air bladders in rear.
Heavy-Duty suspension w/ Bilstein shocks
Custom Arcand Leaf Spring Suspension
Limited Slip rear differential.
Front & rear 2" Class IV hitches
17" x 8.5" One piece Weld EVO Dagger Racing Wheels
Stainless Steel Magnaflo dual muffler system
BFG TA KO LT285/70R17D Tires
PIAA 9005 & 9006 Platinum Super Headlight Replacement Bulb system
K&N FilterCharger® Replacement Air Filter
Yakima Swingdady SwingAway™ 4-bike capacity hitch rack
Auxiliary air compressor unit for tire inflation, etc.|
Seat belts for additional two passengers in rear sofa.
Halogen lights, Chrome grill, Custom AM/FM stereo with CD player
Raised roof with Yakima rack tracks.
Power Systems
Onan MicroLite 2800 On board (vehicle fuel tank feed generator
Delphi AD-244 Large Body High Output Alternator w /rectifiers that have 70 amps diodes.
150 Watt rooftop Solar Cell with high current controller feeing into
Interstate 450Minute reserve deep cycle battery
Blue Sea Systems Battery Isolator/Combiner, Automatic Charging Relay
Xantrex - Link 20 Two Bank Battery Monitor
Xantrex - 4000 Watt Power converter
Remote house battery shut-off.
IOTA DLS-30 Power Converter/Battery IQ Controller automatic 3-stage "smart charger."
BatteryMINDer® OnBoard Desulfators Restorer-Conditioner
Entertainment
7" - 1st row, In Dash DVD/GPS
17" -2nd row, Flip down DVD Pyle 17 High-Resolution Flip-Down Widescreen Monitor with DVD player 24" - Back seating/Bed TV tuner/DVD with External High Definition antenna.
The Smart Light® with Star Monitor
Stinger Rechargeable Flashlight
Cobra 40 Channel CB radio.
Comfort
Overhead bed with reading lights sleeps two. (Vehicle sleeps 4 adult
Window shade package w/ privacy curtains blackout shades and screens
Four swivel, recliner Captain's chairs, rear two are removable
Carefree LB Freedom II 10' box awning
Hide away cash safe
Convenience
Rear backup camera w/ in-dash LCD Backup display.
Central Vacuum system Dirt Devil CV950 LE
Suburban HVAC system w Digital monitor panel that controls 16,000 BTU furnace &
Duo-Therm Roof air-conditioner, 13,500 BTU, which also includes heat strip.
High efficiency 12 Volt refrigerator & 2-Burner range.
Magma Marine Stainless Steel Kettle Gas Barbeque
Corian® kitchen countertops and stainless steel sink
Everpure Carbon portable water purification system.
600 Watt digital Microwave with turntable.
Dining table which can be placed in two positions, including
center of the vehicle to accommodate four people.
Water heater, propane fired, direct spark electronic ignition, 6 gallon
with motor aid heating coil for vehicle engine heats domestic water.
Interior shower and exterior shower with china flush toilet.
Remote controlled three-speed Fantastic® roof vent.
Pressure and gravity fill options for the
30 gallon freshwater tank
16 gallon black water holding tank.
15 gallon gray water holding tank.
35lb. Chassis mounted propane tank.
Professionally install 4 wheel drive conversion
GM Products Overview
Quigley Motor Company maintains a close relationship with GM due to the high quality, durable manufacturing and design of the Quigley products. This provides access to GM Ship-thru for reduced shipping costs to dealers in all 50 states and ensures you retain your factory warranty on the unaltered portion of your vehicle (engine, transmission, rear end, etc).
The proven, durable Quigley 4x4 IFS system provides improved road manners with better ride and handling characteristics, especially for on-road conditions. Maintaining the same ride height gives easy driver access and provides the ability to park in standard garages. Quigley a 3" LIFS option for customers in need of additional ground clearance. The LIFS system will increase center of gravity and thus the vehicle should be driven accordingly.
Also,
FIRESTONE RIDE-RITE - FEATURES & BENEFITS
Firestone Ride-Rite air helper springs are designed to provide extra support to your vehicles suspension through the use of suspension air bags. Ride-Rite kits help keep your heavily loaded vehicle level which is essential for maintaining steering control and braking effectiveness. They also help reduce tire wear and keep your headlight beams on the road.
Ride-Rite kits use Firestone's popular double convoluted air springs. They offer maximum load support for years. The air springs can be adjusted to changing loads, so if you are not towing your trailer or hauling a heavy load you can reduce the air pressure in the air springs and have minimal to no impact on the ride. Need to haul your 5th wheel or gooseneck trailer and don't want the rear of your truck to sag? Simply increase the air pressure in your air bags and you are good to go.
On Oct-05-17 at 12:20:34 PDT, seller added the following information:
MAG-HYTEC'S heavy duty differential covers and transmission pans provide increased lubricant and cooling capacity for hard working recreational and service vehicles. MAG-HYTEC covers and pans set your vehicle apart in both aesthetics and function - cast in A356-T6 aluminum and texture powder coated black with machined cooling fins. Magnetic drain plugs trap worn gear material promoting fluid integrity. Each unit is fitted with ARP 568 O-rings for superior sealing. All hardware is 303 stainless steel, in most applications no gasket or sealant is required, and all MAG-HYTEC parts are covered by a lifetime limited warranty. Depend on MAG-HYTEC when you're pulling a heavy load.
On Oct-07-17 at 02:21:09 PDT, seller added the following information:
MagnaFlow Dual Exhaust Installed, from the Dual CATs back to the custom dual rectangular tips.
Which is more important: great performance or great sound? MagnaFlow Exhaust settles the debate by giving you both! Using decades of experience, extensive research, and field testing, MagnaFlow develops and manufactures durable steel mufflers tuned to provide the proper amount of backpressure, plus a deep, resonance-free tone. MagnaFlow Exhaust is so confident in these mufflers, each is guaranteed for life!
Immediately upon purchasing my van I had the Mag-tec transmission pan added for double the transmission fluid capacity. Then I installed 20 quarts of 100% AMSOIL Signature Series Synthetic Automatic Transmission Fluid, specifically formulated to withstand the rigors of heavy towing, elevated temperatures and challenging terrain. It remains fluid in sub-zero temperatures and provides reserve protection during heavy use and even abuse.
Owner Update
Here's a short update, accumulated from potential customers.
I am the original owner and planned to keep it into my retirement, but a recent bicycle accident has made that less hopeful..
That said, there is no body rust
MPG ~12
350ci iron block, last year!
480LE rear differential
Dana 60, 35 spline front differential
Mag-tec transmission pan with 20 quarts full synthetic
Only ran Mobil1 in the engine.
Windows all around and full tint
Full self-contained bugout campervan
Always stored in a shelter and always out of the weather.
Just spent $3,000.00 replaced entire braking system, including the master cylinder.
That's how I've taken care of it for Years have a huge binder with every manual and nearly every receipt
I used to laugh at the illness forces sale postings, but not anymore.
If I don't get a real buyer, I plan to seal this up for the NE winter and see how I feel in the spring. Gerry--
Mike T
___________________
'95 Ford E250 RB30 PH
Old 11-09-2017, 04:00 PM   #2
It’s near me so I would be happy to check it out for anyone interested.
Greg
Smoker is offline   Reply With Quote
Old 11-09-2017, 04:04 PM   #3
nemesisnight's Avatar
First paragraph seems to state it is indeed a sportsmobile, unless they just copied the layout:
nemesisnight is offline   Reply With Quote
Old 11-09-2017, 04:35 PM   #4
Hey, good catch --- it does say that!
But....hmmm.
This sure doesn't look like an RB-50 layout as he indicates, not one bit....
RB-50 is more or less a copy of a VW Westfalia layout, with a full-width 2nd-row bench seat that turns into a bed.
This listed van has a front-to-rear aisle....
....and 2nd-row captain's chairs...
Mike T
___________________
Old 11-09-2017, 06:28 PM   #5
Check it out
Greg
How close are you would you be willing to check it out? I've talked to him but I'm 900 miles away? Thanks
Lakefever is offline   Reply With Quote
Old 11-09-2017, 07:31 PM   #6
I'm about 45 minutes away, depending on traffic. Sure, would be happy to check it out. Not qualified to do an inspection, but if you give me a checklist I can run through it, take pics, test drive, impressions, sniff test, check rust, etc.
Old 11-09-2017, 07:59 PM   #7
FWIW ---
This van is also currently listed on eBay:
https://m.ebay.com/itm/Chevrolet-250...sAAOSwwGRZ0AFC
The description there adds more photos and some additional info.
Mike T
___________________
Old 11-09-2017, 08:15 PM   #8
Basically just wanted to know if all works and outside is in good condition and overall inside condition. Didn't want to step on Mtn bike roamers toes just chimed in because I'm interested have talked to the guy from eBay ad it's just long way from me.
Old 11-09-2017, 09:05 PM   #9
No worries. If someone is interested in making a run at this and wants a look before coming out to inspect and buy, send me a PM.
Old 11-09-2017, 09:54 PM   #10
Hey Lakefever! All good man.
I'm always looking at vans for sale, like a lot of us....
....but if I post a van on here, it's because I've realized it's not quite right for me, at this time, anyway....so just putting it out there for anyone else it might be a great fit for!
Mike T
___________________
Beatrice
Drizzt
Coddiwomple
Rpence
