Old 08-25-2017, 06:44 PM   #1
MountainBikeRoamer's Avatar
FS: Low miles EB Cruiser Top / N.Y.
A solid one for the East-coasters ---
--- and only 37,000 miles!
Looks well-equipped (and reasonably clean).
No affiliation.
2002 FORD E250 SPORTSMOBILE - $22000 (SMITHTOWN)
Link: https://longisland.craigslist.org/ct...280021443.html
I am selling this 2002 FORD E250 EB 2WD SPORTSMOBILE CRUISER for the second owner. it is excellent condition with 37,145 miles on it. It has a 5.71 Triton V8 engine. With the exception of the hot water heater it appears to be all original. I've had it recently serviced (July 2017) including new front and rear brake pads and rotors, a new Interstate starting battery and an oil and filter change. It comfortably sleeps two and is loaded with amenities. Upper front and rear compartments as well as upper left and right shelves. A two burner propane Atwood cooktop stove, 4CF NorCool refrigerator, .6CF Goldstar microwave SS sink, Atlantic Marine stainless steel water heater, vinyl flooring, LT grey cabinetry, with counter top extensions and side compartments, 12,000BTU Suburban Mfg.Co. furnace,40lb propane tank, Thetford Porta Potti, 7'6" x 10' Easy Crank awning, side window awnings, Aluminum running boards. Class lll receiver hitch. This is a full height Cruiser top with 6'5" head room, 10"x 60" sliding side windows with screens and shades and a 3 speed attic fan. There is a small (nearly undetectable) dent in the R/F fender above the wheel opening as well as some damage to the outside corner of the L/R door. The shroud is missing from the R/R window.
SOLD AS IS.
Available for pick up on long Island, NY.
VIN: 1FDNS24L12HA12190
condition: excellent
cylinders: 8 cylinders
drive: rwd
fuel: gas
odometer: 37145
title status: clean
transmission: automatic
type: van
Mike T
___________________
'95 Ford E250 RB30 PH
Old 08-25-2017, 09:03 PM   #2
I've never seen a Ford with a Chevy engine
It was all going so well til I saw those frighteningly horrible awning things on the windows.
Old 08-25-2017, 09:27 PM   #3
Haha!
Enough determination, and apparently a 5.7 Chevy will fit in...anything?
(Btw....ya got me now thinking of Johnny Cash's immortal song lyrics....
"....so we drilled it out, so that it would fit
And with a little bit of help from an a-dap-ter kit
We had that engine runnin' just like a song..."
Mike T
___________________
Old 08-25-2017, 09:51 PM   #4
No affiliation.
SOLD AS IS.
drive: rwd
fuel: gas
odometer: 37145
title status: clean
type: van
I was bidding on this on eBay, ended auction at $10k which was below reserve.
40lb propane tank seems huge! Can propane run the other electronics in the van besides the fridge?
MilkAndRelish is offline   Reply With Quote
Old 08-25-2017, 10:08 PM   #5
Haha!
Just the heat and hot water, if equipped, and not the fridge on this one. That's looks like a 12v Norold fridge.
