Old 08-24-2015, 09:53 PM   #1
Esmi2's Avatar
If you need something like this ...
... here's one of these.
From Craigslist in Mendocino County, Californy..
http://mendocino.craigslist.org/cto/5146541988.htmlhttp://mendocino.craigslist.org/cto/5146541988.html
COPY READS:
1995 F 350 chassis with a 95 12 valve Cummins but has been turned up. with bigger turbo piping and Industrial injectors, fast fuel pump ,4 inch straight pipe all the way back with six inch tip .with a new rebuilt 4 speed Allison transmission with p.t.o. auto still under warranty maybe 1500 miles on it.has air system with train horn ,air ride seats ,new airbags and it has a Jake also. gooseneck ball in the bed and a 5th wheel hitch .full sleeper couch folds down into a bed, DVD player and LED lights all over inside and blue ones behind the grill , fog lights.100 gallon fuel tank. New tires,new brakes all the way around,new wheel bearings and tie rods and alignment,new batteries .and new master cylinder,Rhino lined bed liner,no fluid leaks whatsoever , new radiator and overflow tank,new shocks, new air compressor ,new starter, fresh oil change and fuel filters .low miles 150xxx
(Not mine, no affiliation)
Esmi2 is offline   Reply With Quote
Old 08-24-2015, 10:51 PM   #2
Re: If you need something like this ...
What, no 4WD? Pass.....
Old 08-25-2015, 06:24 AM   #3
That's just awful. That is all.
Old 08-25-2015, 06:57 AM   #4
I see a solid front axle, leaf springs and hubs. I think it is 4x4.
