Old 09-29-2008, 06:12 PM   #1
Nudger's Avatar
2006 SMB V-10 intermittent starting problems
I have a 2006 SMB V-10 with 27K miles. It has been really reliable, but for two occasions. On both these occasions, I went to start the vehicle (once after sitting overnite, once after being off for just a few min.). I turned the key and nothing happened - didn't turn over, click, but all lights, electrical equipment, etc. worked fine. Then, after 10-15 min. sitting each time, it starts fine!!
First time this happened I took it to a Ford truck mechanic, who checked things out, found no problems. He added a cryptic "this happens with those V-10s" - but offered nothing really useful by way of explanation.
Has anybody here experienced this before and/or have any idea what's going on?
Thanks,
Nick
Telluride, CO
P.S. I apologize if this is covered in another thread - I checked some, but couldn't find anything relevant to this specific problem.
2006 SMB RB E350 4x4 V10
Nudger is offline   Reply With Quote
Old 09-29-2008, 09:46 PM   #2
Intermittent Starting
Nudger ,
My daughter's 2003 Quigley E-350 V-10 did the same thing , first diagnosis by Ford was a sticking Starter Solenoid , which they replaced all was well , one month later they changed the complete Starter , good for approximately one year and then it started again .
They checked the complete system and changed out the cables and it has never done it again to date . Always happened like yours after sitting over night and generally at temperature's under 50 degrees .
Greggde
Old 10-10-2008, 02:40 PM   #3
I experienced this problem once as well (actually, my wife did). When i got there, all i did was put the shifter more firmly in Park and the problem went away....i later tightened a part of the linkage that was loose and it has not happened since.
Joe Skrivan
E-350 V-10; Penthouse, Custom Interior
skrivan is offline   Reply With Quote
Lola
Eddie Haskell
Sporty
BusTalker
