Old 10-05-2010, 11:55 PM   #1
2011 E-series specs
For those interested, here's the 2011 E-series specs.
https://www.fleet.ford.com/truckbbas...ed_Chassis.PDF
Not many changes, however I did notice one significant change...
The E350 extended now comes with a Dana 70 full floater (has been done before.... it's come and gone depending on year) but now has a 10.5" ring gear. This is a first for the E350 van. My van came with a Dana70, but had the 9.75" gear originally, and I had the carrier swapped so I could have the larger 10.5" gears.
I have the 4.56 ratio, and at 22,000 pound it has to be a 15% grade and outside temp over 100F to make my diff oil get to hot ( my personal "too hot" temp is 280F, even though the gear oil specs say 330F).
Shorty vans still have a semi-float, and 9.75" gears.
FWIW - the E450 gets bumped up to 10.75" gears, and also got a bump to 22,000 GCWR.
Old 10-06-2010, 12:09 PM   #2
Re: 2011 E-series specs
Not all the charts agree with each other. If you look at the chart for the E350 Regular/Extended van, it calls for the 9.75" semi-floating axle. The 10.5" full floater axle is listed for an E350 cutaway - that is where the Dana 70 (10.5") axle I got came from.
I'll bet it is just an error on the Rear Axle Specs chart, and the full-floater is not available on the vans, just on the cutaways.
SOLD04 EB350 Custom Floorplan
6.0 PSD 4.10 Posi
Salem Kroger coil spring 4wd
2015 VW GTI
Leaving CA for WA
Old 10-06-2010, 12:38 PM   #3
mjeffrey's Avatar
I don't know anything about axles, but from what I've read it appears that my '08 RB passenger van has a full floater (judging by the big hub coming through the rear wheel):
Is that right?
Does Ford sometimes throw in a different axle, depending on what's at hand?
Cheers,
Mike.
mjeffrey is offline   Reply With Quote
Old 10-06-2010, 01:06 PM   #4
Certainly that picture is a full-floater. Why one would end up under an RB is anyone's guess.
6.0 PSD 4.10 Posi
2015 VW GTI
Leaving CA for WA
Old 10-06-2010, 03:44 PM   #5
Silver350's Avatar
Is that right?
Cheers,
Mike.
We have the same van and my rear axle is identical. Maybe Ford standardized its axles by 2008?
Old 10-07-2011, 12:56 AM   #6
tildadog's Avatar
I have a 2008 RB passenger van that also has a full floater, it was one of the reasons I picked it up used and had it converted by Quigley. I was told by Ford dealership that it was an option but all the RSC vans seemed to have it.
Yurtle the Turtle rides again. (apologies to Dr. Suess)
tildadog is offline   Reply With Quote
quigley
4x4Ken
MCSporty
MSD
