Old 03-09-2017, 03:32 PM   #1
Flux's Avatar
2013 6.8l V10 Low Idle and Surging
So a little bit ago I had some surging in my V10. Kind of a low idle too at about 500rpm which is still going. Here and there the idle would jump up to 1300 in park and then if I throttled a bit it would seem like it wanted to stall. Noticed a little bit of surging around town too and kind of late throttle when I gas it a bit.
After some reading my best guess is to clean the MAF sensor and check the vacuum hoses around the throttle body. From what I gather there is no Idle Air Control Valve on these throttle by wire motors so that is out. Another guess is the TPS. So my course of action will be to clean the MAF with MAF cleaner, check for vacuum leaks at the throttle, then maybe swap the TPS if that doesn't do it.
I have noticed that since the 4x4 conversion I have kind of lost my "roll" or that the van decelerates pretty quickly with no throttle. I guess this is to be expected, but maybe it's related to the low idle condition which I think existed before the conversion. Haven't been putting too many miles on the rig as it's getting built out and the kids have no seat.
Any suggestions are greatly appreciated.
<br>
Old 03-09-2017, 03:41 PM   #2
Vacuum leak or sticky throttle body are definitely both plausible, because vacuum still controls fuel pressure. Spraying carb cleaner on vacuum lines will expose a leak. It will surge when you hit the leak.
Even a little bit of oil vapor deposits can cause the throttle body to stick. It can be cleaned, but disconnect the battery because the motor is strong enough to take off a finger. Also, if you do see a film of oil vapor deposits, you might want to think about goin full synthetic...
Old 03-09-2017, 03:45 PM   #3
Flux's Avatar
I'd see those vapor deposits inside the throttle body??
And thank you as always carringb!
<br>
Old 03-09-2017, 04:08 PM   #4
Yeah if you see a brown film that's the deposits. Of course, dirt can also make it stick if the filter wasn't fully seated. And oiled filters can do it too if over oiled
*edited for bad autocorrecting
Old 03-09-2017, 04:09 PM   #5
Flux's Avatar
I got some work to do. Thanks.
<br>
Old 03-09-2017, 04:46 PM   #6
Bbasso's Avatar
I had those same issues on my V10, it was the MAF sensor... every three to four thousand miles I'd have to clean it despite having brand new air filters and a completely sealed box. I would get a CEL and sometimes a hidden one regarding the MAF.
I took it as part of the norm...
Rob.
Current:
And had three other E350s...
Old 03-09-2017, 04:52 PM   #7
Flux's Avatar
I hope it's just a dirty MAF, that would be a piece of cake. The low idle makes me think that could be it.
Didn't check for codes, which I should have.
<br>
Old 03-09-2017, 08:44 PM   #8
winmag4582001's Avatar
Does it have a MAP sensor? My 5.8 Bronco had the same problem when that sensor went bad.
2010 Ford E350 EB 6" Weldtec Lift
2017 Subaru Legacy
1990 Volvo 240GL
2x 1987 BMW 535is
1995 BMW 540i6
winmag4582001 is offline   Reply With Quote
Old 03-09-2017, 11:50 PM   #9
Bbasso's Avatar
Should be easy to do, 20 mins tops.
Rob.
Current:
Old 03-10-2017, 07:20 AM   #10
I had a lot of problems on a trip last summer with my V10. Surging, coughing, loss of power, eventually total shutdown. It was a bad seal around the MAF where my AFE intake had split due to a bend that was too tight. V10's mess up so rarely I'm guessing MAF too. Check all your intake connections.
[HOONIVAN]
Shaggy
Serenity
Makalu1
