Old 08-06-2012, 10:06 PM   #1
4wd kit for e250?
hi i am about to buy a 95-2002 e250 and turn it into a off road campervan the 4wd ones are a little more$$$ so i am going to go with a 2wd and put a lift kit on it and get a winch for it but i was wundring if they have a 4wd kit for a 2wd e250 so i can change the 2wd it a 4wd? i have looked around and havent found any but i figured that if anyone one would know it would be you guys and gals i would just spend the extra money and get the 4wd but i am 18 and going to school so i am on a budget so any input on the subject would be great thanks everyone!!!!
campervan is offline   Reply With Quote
Old 08-06-2012, 10:11 PM   #2
BIGVANS's Avatar
Re: 4wd kit for e250?
First of all try to get an E-350 (One Ton)
For the 2X kit, check these guys .....
http://www.camburg.com/ford/e-series-van-1/
For the 4X4 kit you can't beat U-Joint
http://www.ujointoffroad.com/
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 08-06-2012, 10:37 PM   #3
thanks soooo mutch that helps alot i just emailed them i cant wait to hear back. this maybe a dumb question but why should i get the e350 insted of the e250? i will go with the e350 sence you know more about smb i just was curious
Old 08-07-2012, 04:17 PM   #4
Total weight rating for one. Not sure if the frames are different...carringb posted something on this way back IIRC.
Old 08-07-2012, 08:34 PM   #5
BIGVANS's Avatar
The only down side I see to the E-350 (1 Ton) over the E-250 (¾ Ton) is that a few states make you register it as a “commercial vehicle” (because it’s not a SMB “RV”) so the plates may be a little more expensive.
WAY worth it to me!
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 08-07-2012, 09:40 PM   #6
If you go here, you can cmopare the specs for the vans you are considering:
https://www.fleet.ford.com/truckbbas.../techspec.html
The frames are the same between the E250 and E350RB. But E250 springs are softer, and it may have a lower rated axle. Unfortunately, even Ford's own publications fail to account for all body configurations. Some vans listed with a semi-float rear axle may axle come with a Full-Float (Most EB passenger vans will actually have a 7800# full float axle for example). So.... when shopping it pays to peak underneath to see which axle it really has.
Old 08-08-2012, 07:54 PM   #7
Send a message via Yahoo to ghettojohnny
Campervan,
have you already found a van yet?
What area are you in?
The shop van here is for sale and is in the process of finnishing up the UJoint kit on it.
It's a 2005 E350 SuperDuty 6.0l turbo diesel that just had a bunch of preventive measures down and new parts replaced.
bigger tires already installed, Aluminess ladder, fender flairs,roof rack system,window tint,and new Kenwood navigational DVD stereo installed.
just an option.
let me know
John
ghettojohnny is offline   Reply With Quote
"Toaster"
LostInTransit
Van22
Van22
