Old 10-14-2012, 11:19 AM   #1
SheepShagger's Avatar
6.0 Blue spring (fuel pressure regulator)
The O ring on my fuel pressure regulator started to leak recently, and while researching part numbers I came across a bunch of posts on the 6.0 blue spring. I had seen these topics before on the truck 6.0, but never really given much time to researching it.
Anyway, it transpires that the van can suffer from the same issue as the truck, in that the spring can weaken over time and not provide the correct PSI to the fuel rail which will cause injector failure. Under 40psi or over 70psi seems to be the numbers.
So since I was there replacing the O ring I decided to install the ford rebuild / upgrade kit. The van kit seems to be identical to the truck kit except the truck includes a new external valve body and the van doesn't. Both kits are the same price though.
Anyway, the point of this post is the fuel pressure regulator is on the top fuel filter housing, and isn't much more work to do than changing the filter. So seems for those of you who change your filters it *might* be good insurance to pop this kit in at the same time you do your next filter change. Prep is to remove all the same stuff you would to gain access to the filter, move/lift the wiring harness as normal, then remove turbo intake pipe that runs from intercooler to alternator area, and remove the intake pipe from air filter to intake.
Van part# is 4C2Z-9T517-AA.
Dealer MSRP is $75, can be had for $50 from many places. Took an extra hour to install over the normal fuel filter, real mechanic time probably 30mins or less.
BTW. I've been fighting a faint diesel smell in the cab for quite some time, it's been very on one day and off the next so very difficult to trace down, I'm quite sure this is the culprit.
Old 10-14-2012, 12:04 PM   #2
ridintall's Avatar
Re: 6.0 Blue spring (fuel pressure regulator)
Yep, did this upgrade to my van as part of preventative maintenance.
ridintall is offline   Reply With Quote
Old 11-18-2012, 08:13 PM   #3
UJOINT's Avatar
We do it on all 6.0's that we upgrade, easy to do. Just an FYI, the truck kit is different since the fuel bowl is not the same (learned this the hard way thanks to my Ford dealer!)
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 11-18-2012, 08:40 PM   #4
Mine went a couple of years ago. Same thing... a smell of diesel.
Old 11-18-2012, 09:30 PM   #5
If you are doing filters, I also recommend cleaning out the sump in the HFCM (Horizontal Fuel Conditioning Module). The small sump that serves as the water separator can accumulate dirt/mud/rocks (if you've been using poor quality fuel), enough so that it can't separate water anymore. Just be sure to order the new o-ring first, cause its nearly impossible to make the old one stay put while putting the cover back on.
Old 11-18-2012, 10:01 PM   #6
Geesh carringb, you ARE the engine Wiki
Thanks
