Old 09-14-2018, 03:53 PM   #1
6.0 parts update
Hi All,
I remember seeing a post on here that describes what all parts to change in addition to the oil cooler while in there. Off the top of my head I remember,
  • dummy plug(s)?
  • EGR cooler
  • stand pipe - is this the turbo feed line?
I'm sure I'm missing something.
Bought a 2005 Excursion that needs oil cooler replaced.
karma is offline   Reply With Quote
Old 09-14-2018, 06:20 PM   #2
ShuttlePilot's Avatar
Per Member Joe H and a list I concur with. Although JoeH's list in my opinion would be the end all be all 6.0 upgrade as it would require pulling the motor to complete. I would also change the small rotating bits at the same time like idlers, vaccuum pump, ect, ect, ect. The thread can be found here:
http://www.sportsmobileforum.com/for...tml#post202016
Here's what I would consider the full meal deal on a rebuilt (or bulletproofed) 6.0 powerstroke.
-ARP head studs. That means the motor has to come out.
-Heads. New or resurfaced and were they o-ringed?
-HPOP. 2004.5+ not known for failure but ask anyway
-upgraded one-piece snap to connect HPOP fitting
-Dummy plugs (upgraded parts by Ford for injector health)
-Standpipes (upgraded parts by Ford for injector health)
-EGR cooler with the round tubes or BPD cooler or an EGR delete.
-injectors. Original or remans. 100k is when they start to go.
-New oil cooler. OEM and not a Dorman.
-water pump. Go BPD or Dieselsite for the metal impeller
-turbo reconditioned.
-upgraded turbo oil fill and drain pipes
-FICM rebuilt
-upgraded alternator and fresh batteries
-coolant flush and Ford Gold replaced with a CAT EC-1 rated ELC coolant
-new charge air cooler (CAC) boots
-coolant filter
Hope this helps trigger ideas for you.
- Eric
2005 SMB RB 4x4 6.0 PSD
A rocket on the pad is safe,
