Old 04-24-2013, 10:47 PM   #11
AndrewST's Avatar
Re: 6.0 PSD just dies
Originally Posted by daveb
Herb, Sac is about 2 hours away. ...
What is 2 hours driving in the US... around the block...
Old 04-28-2013, 10:31 PM   #12
utahscott's Avatar
Make sure your oil isn't low. The 6.0L will cut off the fuel if it gets even a hiccup of low oil pressure...
2004 RB350 SMV 4WD
6.0 PSD 4.10 ARB Lockers F&R
Electric PH with Rack 2x 95W Zamp solar
ARB Intensity Spot 2x Flood 2x
utahscott is offline   Reply With Quote
Old 04-29-2013, 09:33 AM   #13
Dave,
Sounds like it could be a harness that has rubbed through and shorts out, but only on the right bump or whatever. Can be difficult to troubleshoot.
Good luck,
Old 04-29-2013, 12:55 PM   #14
Thanks guys. Never thought about the oil. I'll be hooking it up tonight to look for codes. The wierd thing is since the four shutdowns I never had a problem. I thought about the harness but it almost always shut down while barely moving or completely stopped. The Miami Trail is one rough run and I never had a problem on it until I came to a stop at camp where again I wasn't moving. At the opposite end of the coin, it occured once while moving with some throttle applied... didn't die just started to and then came back up.
Sure hate to have to take it to Ford. I'm hopeing for an engine code!
Old 04-29-2013, 09:49 PM   #15
NO CODES
Well I also found out that I can't program the speedometer for 315's. Oh well, we got it closer. We re-flashed it so maybe that will help.
I think I'll still let Ford check it out but I doubt they'll find anything. I'll just cross my fingers.
The last time I went to Yellowstone, I had a similar problem but it acted more like bad fuel. The dealership outside of Logan couldn't find anything either and it ran fine until last week.
Old 04-30-2013, 05:50 AM   #16
Sacramento is sounding better and better....
Old 04-30-2013, 08:00 AM   #17
A 10K bullet proof sounds even better.
Old 05-02-2013, 11:17 AM   #18
twogone's Avatar
'95 SMB E350 Quigley 7.3
https://www.taylorarts.com
Old 05-05-2013, 01:24 PM   #19
Hum, looks like a great place
Well I don't want to add fuel to the fire; I have enough crap going on right now.
Ford did their thing. Just like my buddy they re-flashed the computer, and no problems no codes. I had the EGR cooler/valve pulled and cleaned, did all the fuel filters plus a oil change that was coming anyway.
Yesterday the van died again... again at about 15mph with nothing on the throttle. Seemed like it coughed a couple of time on a hard throttle.
It still seems electrical but what would a failing fuel pump do?
I really don't want to start replacing things just because. That can get costly. I have a concern about the wire harness. I've had the separator open so I could make sure the batteries are OK. Starts fine. I'm also wondering about upgrading the computer. One of the mechanics swears by a company that does it but I don't want a power upgrade just a more solid platform...is there such a thing?
Yep Herb Sac is sounding better.
Old 05-05-2013, 02:18 PM   #20
Sorry to hear about your continuing troubles Dave. I sympathize, as I just went through two back-to-back issues myself on my 7.3L. One week it was the HPOP, then this week the CPS took a dump on me, at a busy intersection of course. Though I think it's just a fluke, and I think there's no reason not to trust it, between the issues, and a health issue with my wife, I'm likely going to pass on Overland Expo later this month. I'll probably just do a 3-4 day shakedown run much closer to home, in preparation of a 12 day trip with my son in June.
As for your computer, are you talking about the FICM? Here's the thread on that.
viewtopic.php?f=39&t=8854&hilit=ficm
Margot
FCAshevlle
Turtle
rafeman
