Originally Posted by Jeffrey
New turbo install being done today. Since I now understand these things a little better I'm thinking of a turbo boost gauge like this one. I see some come with a sensor and a wire and some use a hose to measure vacuum. Any preferences? Is it easy to install?
i like the isspro gauges, as they look close to the stock cluster.
i prefer electronic boost gauges, easier to run wires then vacuum hose, and if something happens to the wires the gauge doesn't work, if something happens to the boost line to a mechanical gauge, you now have a boost leak. unfortunately though, injection controller needs a boost line run to it. easiest place to add a sensor is to delete the IAH and put the boost sensor there, or if running a mechanical gauge, tee it into the line to the MAP near the intake Y.
