Old 11-16-2019, 07:20 AM   #1
Question 6.0L w/ Transfer Flow tank - Fuel Filter
Hey All - I think it's about time to replace the fuel filter in my 2010 6.0 PSD with the upgraded Transfer Flow tank. Any special notes with changing this due to the upgraded tank? Where are the filter(s) in this beast?
Thanks.
crawpappy is offline   Reply With Quote
Old 11-16-2019, 12:12 PM   #2
pjpvi's Avatar
There is one underneath the van (driver's side) and one on top of the engine. If you google it you should find the info you need. The TransferFlow tank doesn't change anything about stock filters.
To get to the one on top of the engine you need to take screws out that are holding the harness above the engine and pull it up and out of the way. I use a bungee to hold it up and out of the way. For the one under the van you need to drain first with the valve on the bottom of the filter.
It's not a bad project to do.
Phil
- 2005 EB50 6.0PSD - SMB 4x4
Vanna
gahamby
2006 Ford E250
Lenny
