Old 03-25-2014, 10:40 PM   #11
Re: 7.3 Any external noise reduction options?
I also believe there are some sound dampening kits for your hood that may help as well. Does your hood still have the stock noise barrier / dampener material?[/quote]
Still have the stock noise barrier under the hood. good call.
Mountainair is offline   Reply With Quote
Old 08-07-2017, 09:37 PM   #12
I added this 7.3L Diesel Fuel Rail Crossoverâ„¢ (FRx) 99-03 Powerstroke and it seemed to help
2003 7.3 12 Pass
Gordo is offline   Reply With Quote
Old 08-10-2017, 11:53 AM   #13
bet on black's Avatar
make the stereo louder...
bet on black is offline   Reply With Quote
Old 08-18-2017, 12:55 PM   #14
Bbasso's Avatar
I too have read the High Pressure Crossover can help to quiet down the injectors.
Rob.
Current:
And had three other E350s...
Old 08-18-2017, 02:11 PM   #15
TomsBeast's Avatar
The 7.3's are sure rattely engines, even for a Diesel.
You've probably already looked, but check your doghouse engine cover. Check the seal, as well. Mine came back from being worked on, noticeably louder. I looked at the cover, it looked and seemed fine, until I took it off. They missed one of the tangs. I reinstalled it myself, made a big difference.
Old 08-22-2017, 07:27 AM   #16
djbonsu's Avatar
I have install this and it does help BUT only at idle and when the engine is warm.
2000 E350 Cargo PSD w/ UJOR 6" Lift
djbonsu is offline   Reply With Quote
