Old 02-06-2015, 10:30 AM   #1
schluchtenflitzer's Avatar
7.3 did stop runing :-(
My 2001 7.3 stall and did not start anymore. It droves perfect till i store it for 2 month. After this it start pefect and after i let him idle 2 or 3 min it stall sudenly. After starting again it nocks very hard -i think it was on some cylinders- and was running very bad. I just drove it back to his place. So 3 minutes more most in idle. But i had to push the throttle a lot so that it does not stall again. Now after it cools down ( we have about 50F here) it does not start and smoke leaved the exhaust during starting. Scangauge does not show any faults. Unfortunatly i have no diagnose tester.
I checked a lot of things: fuel, pump, fuelfilter, changed CPS....then i warmed it up with the blockheater and i get him starting. I detected that the exhaust on the passanger side bank is staying cold. So the complete bank seems not running.
Of course -as it is the easiest work i want to check the IDM but here in Germany the 7.3 are rare and so nobody is around the corner with a good one i can ceck. So i disasambled the valve cover. What a f&%.. job! I hope i have never to do this again!
What i saw
The plug inside the cover was coming loose. I pushed it back and the engine runs perfect!
I also checked the driver side and there also the plug was very loosen!
After some surching in the www i founf´d that Ford sell some RETAINER - Ford #2C3Z14A163AB to help the plug not get loosen again. As i want not wait for shipping it to germany and also the costs i decided to go my own way. I know some take a quarter and cut it to make the job but i hate to take a pice of metal into the engine what can cause damage if it get out of the plug.
So i took an old credit card and cut it to fit perfect into / unter the plug. As it was to small i had to take it double each side.
See pics
loosen plug
that is the pice i built for save the plug com out again
ready to go!
www.Dieda-unterwegs.net
schluchtenflitzer is offline   Reply With Quote
Old 02-06-2015, 10:44 AM   #2
Re: 7.3 did stop runing :-(
I'm glad you got it sorted out. I've seen where the use of quarters (Euros?) is known as the 50cent mod (one quarter for each side), but I agree, using pieces of metal under the valve covers doesn't seem like a good idea.
Depending on the number of miles on the engine, you may want to look at replacing the harness that resides under the valve cover. It could become brittle from age and heat. Now it makes me wonder about the harnesses in my 7.3L
http://www.riffraffdiesel.com/under-val ... ess-99-03/
Old 02-06-2015, 11:04 AM   #3
rallypanam's Avatar
This is the best repair job I have ever seen...
Old 02-06-2015, 01:08 PM   #4
That is one slick repair. It is now in my notebook of 7.3 information. Whenever I learn something new, I jot it down in the notebook for future use if needed.
hogasm is offline   Reply With Quote
Old 02-06-2015, 04:41 PM   #5
larrie's Avatar
Great job troubleshooting the problem. The fix is elegant.
Larrie
Old 02-07-2015, 05:01 AM   #6
And so many of us think credit cards are useless?!
Often times replacement connector shells or repair pigtail leads are available either from Motor Craft or other sources, direct fit for most any Ford wiring harness connector. Those that are part of an assemble (like the ECM PCB connector) aren't individually replaceable.
Any connector shell with locking tabs are subject to breaking which can cause loss of contact and the situation Schluchtenflitzer describes. Here is a link to the current Motor Craft catalog which does require a bit of familiarity first but is easy to quickly see how its arranged, how to find your particular part.
http://www.fordservicecontent.com/pu...torcatalog.pdf
I've found it helpful from time-to-time---the Motor Craft part numbers can be crossed over to other manufacturers and supplies, some times at a savings over the Motor Craft brand.
Old 02-07-2015, 08:11 AM   #7
Extremely useful catalog JWA! thanks.....saved the PDF for future reference.
Old 02-07-2015, 09:19 AM   #8
E350's Avatar
Good diagnosis! As BroncoHauler says, that is commonly referred to as the "50 cent mod." One grinded down U.S. Quarter per UVCH connection. In your case I guess the name would be based on the credit limit of your credit card.
50 Cent Mod:
http://www.ford-trucks.com/forums/92...ml#post8408158
General 7.3L PSD Sticky:
http://www.ford-trucks.com/forums/40...ech-links.html
Ford apparently makes a new UVCH which doesn't come loose and doesn't have this problem.
